What Oil & How Much On a WD
hardwood61 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Topic: What Oil & How Much On a WD
    Posted: 18 Aug 2010 at 8:47am
Anybody know what type of oil to use in a WD's transmission and differential?  Leaving for hunting land on Friday and wanted to put in fresh oil - just bought the tractor and waiting on manual I ordered.  I appreciate any help.
Larry
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 8:59am
I believe it hold 17 quarts, I use 80/90 gear lube. there are 3 separate comparments. Drain plugs are located on bottom of transmission, bottom of differential, and bottom of hand clutch housing. Fill all 3 compartments through transmission filler plugs (2)
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 9:05am
Thanks Matt,  are you saying you drain 3 plugs but you only fill using 2?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 9:14am
Yes, there are 3 lower "sumps" for the compartments that need to be drained. the cases are "open" on the inside so they will fill through the transmission filler holes
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 9:19am
OK!
Thanks!
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 1:26pm
The 2 rear most plugs on left check same levels but for filling you need both or take forever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 8:21pm
So then ... do I use 80/90 gear lube for the hydraulics and transmission and differential?  Seems odd to use for hydraulics - with the possible contamination.
After re-reading the responses I think I get it now ... Gear lube for the clutch, transmission and differential, but the hydraulics is a separate compartment with its own drain plug and fill at dip stick ... is that it?  Just trying to make sure I don't screw it up ... hurry up USPS with my manual!
Edited by hardwood61 - 18 Aug 2010 at 9:08pm
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 9:07pm
The transmission, differential and hand clutch fill plugs have square heads; different sizes.
The filler with the "bayonet" dipstick is for the hydraulics. Holds 6 qts. Originally called for 20 Wt non-detergent oil but most use universal hydraulic fluid nowadays. In addition to the "magnetized drain plug on the bottom of the housing, there is a small drain plug
on the hydraulic control housing near the pump on the RH side which should also be drained.
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 9:21pm
I use JD hi-guard universal trans/hydraulic fluid. Works really well.
CA Tractor
