what model 3 point A-C mower is this?
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Topic: what model 3 point A-C mower is this?
    Posted: 29 Jul 2012 at 4:13pm
we have had this mower for  25 years + it came with a one sixty dad bought .does any one know the model? I cant find a tag on it. I have never seen another but i wasnt looking either. just wondering thanks ...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 4:34pm
 Looks like a #160, but I never seen one with a 3 point before.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 5:19pm
http://i.ebayimg.com/t/Allis-Chalmers-Models-160-172-Rotary-Mower-Operators-Manual-/00/s/MTIwMFgxNjAw/$(KGrHqFHJDcE90pevi)lBPejCuc5Yg~~60_57.JPG
PlayGun View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PlayGun Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:13pm
It sure looks to be in good shape, the side walls ares till intact and no bad rust, that's pretty neat.
Hopefully Future AC Man! Ride With Jesus my friends!     Lonas
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:21pm
the shame of it is that is sat outside for years until we sold the cows. the weather didnt do the paint and decals any good, but now we keep it inside. we still use it to mow the old  heifer and dry cow lots  off. it works real good ....Jb
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:27pm
I have only seen the model 160 with a snap coupler / 3 pt hook up.Have never seen a 172 without the wheel assemblies. Have thought about converting one of my 172,s to a three point hook up.May be a little heavy, but with a tail wheel it should work. Anybody have a pic of a 172 or 184 with a 3 pt hitch. I believe one pictured in this post is a 160 but I could be wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:33pm
the one pictured is a little heavy it doesnt look like it but it makes the front end light on the wd45 wide front when you transport it. we have a 172 woods that has the wheel kit on it and i like to use it behind the wd45 narrow front...Jb
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:44pm
How wide is it JB ? Your woods 172 is a 6 footer , is this A/C as wide? Just curious. Love playin with these old mowers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 10:06pm
i think it is a 5' mower , ill measure it tomorrow when im at the farm.guess thats how they came up with the model numbers 160=5'  172=6'...Jb
DPrestonOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DPrestonOH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 10:13am
We had a brush hog exactly like this back in the 60's and it was a 5' model.  We pulled it behind a D15.  It was one heck of a mower.  If you could get the front of the D15 over it,  the brush hog would cut it.  We had about 300# of weight hanging off the front end of the tractor too.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 10:30am
Here is a 172 pull type that I dont need, have another one.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 10:51am
I just bought the 3pt 6 foot version of that mower for $300. Were could a guy find the main bar that bolts to the shaft and blades. There is a chunk broke off of mine enough to were I had to weld a block on to balance it so I could use it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 4:02pm
That is the very rugged 5' 160 model and I have a 3-pt. model also. Tough little cutter and I run mine behind a D15II equipped with a SC/3pt. adaptor. Break out the 6' Bush Hog for getting up against fence lines and can appreciate the ratchet type clutch on the 160 as it is a nice set-up to have.
If it sat for years you may want to check the large retainer nut is secured and the spring tension occasionally on the PTO adaptor to the gear box. Chain gaurd was an option on those so be careful if you are running it without chains or rubber on the front as those big heavy blades can really sling stuff at you . . . . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 6:15pm
Richard , throw that on the truck next year and bring it to Dale's , I could use another.
