What media to use for sand blasting |
jerbob
Topic: What media to use for sand blastingPosted: 08 Jan 2018 at 1:44pm |
Good Day AC fans.
Due to good ol wintertime in Michigan, and not wanting to do nothing, I have taken off items that I can sand and grind to be ready for paint. Floor plates, air cleaner, seat frames, front grills and so on. For much of the small parts I am just using wire brushes and wheels in a good angle grinder. But diamond plate and bigger items, are very time consuming. Also going to use chemical stripper to speed up some of that as well. For parts I want to try sandblasting, What media is best. I don't have a large vertical compressor. Mine is a 5hp, 25 gallon unit that runs on 220 single phase. Puts out 12.7cfm at 40 psi and 10.6 at 90 psi. Max pressure is 120psi. Kick in pressure is 90 and Kick out pressure is 120. These are low I heard to use a media blaster but would like to try. Do I use course media, walnuts or what for paint and rust. Thank you everyone. |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 08 Jan 2018 at 2:04pm |
at my previous employer we used fine sand in a large engine powered compressor and blaster, unless blasting thin sheet metal we went to the small pressurized blaster fed off the shop air. sand is easiest and cheapest media im aware of. just be sure to wear a mask so you don't breath the silica. people will say don't use sand but If your not breathing it youll be fine.
you can blast with your compressor it just wont be continuous. get a pressured blaster like 50lbs or so. stay away from the suction type they are junk, the sand doesn't get enough speed to do much. harbor freight or northern tool etc carry these.
Edited by CAL(KS) - 08 Jan 2018 at 2:06pm |
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 08 Jan 2018 at 3:07pm |
Make sure you don't blast inside or by the doors of your shop.That sand gets into everything and be a real problem to clean good enough to paint. If I was going to get serious again about painting I would invest in a baking soda system. You don't have to worry about removing glass, chrome, or anything like that. Just blast her clean of rust and paint, blow it clean. tape and paint. Just about that simple. You're probably just going to keep it simple, so the silica sand works good. Absolutely do not breath it. Worse than smoking. But enjoy you project and we all would like to see it when it's done.
jerbob
Posted: 08 Jan 2018 at 5:49pm |
Pics will be sent for sure. Thank you for the advice.
jerbob
Posted: 08 Jan 2018 at 5:51pm |
Thank you Cal. I have a water sand blaster but can't use in winter of course. My power washer is 4,000psi hot water and steam. Will try that in Spring to see how it performs.
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 10 Jan 2018 at 7:30am |
I do Not have a sand blaster that works with my pressure washer but I think that such a water blaster would be far superior to using air and sand. The water plus sand will have higher striking inertia than air and sand. Please comment
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35650 |
Posted: 10 Jan 2018 at 8:56am |
If can find it locally, we used Black Beauty media around here. Is basically cinders ground to small fragments/powder, cleans exceptionally fast at less air pressure with less potential for silica poisoning.
jerbob
Posted: 10 Jan 2018 at 9:54am |
I agree but have not had the chance to try it yet. Its a siphon set up so not pressurized in that respect but at 4k psi, and almost 5gph it really puts out. Looking forward to some spring weather to try it. Also have a local guy whom is highly regarded that has a traveling sand blasting outfit and will come to my place to sand blast if needed.
I am taking the floor plates, exhaust manifold, battery boxes and any other parts that come off to them for a cleaning. They can do soda, glass, walnut, sand or silica blasting. Still would like to do myself as I enjoy the time spent on my old girl. |
jerbob
Posted: 10 Jan 2018 at 9:55am |
I just looked it up DMiller and found it at Tractor Supply. Course and medium grit. will try a bag of each when ready.
Thank you for the tip. |
DMiller
Posted: 10 Jan 2018 at 5:24pm |
Use a respirator with good filters, still loads the sinus and lungs with tiny particles.
jerbob
Posted: 10 Jan 2018 at 6:04pm |
Thank you.
LeonR2013
Posted: 11 Jan 2018 at 9:14pm |
When Cooke Sales and Service was here in Fulton they cleaned dozers with high pressure hot water and it did a good job.
jerbob
Posted: 12 Jan 2018 at 6:15am |
Agreed Leon. I power wash my tractor and skidsteer with hot water high pressure water with detergent added in and it really blows off grease, dirt and loose paint off.
Dave (Mid-MI)
Joined: 12 Sep 2009 Location: Hemlock, MI Points: 576 |
Posted: 26 Mar 2018 at 11:08am |
I second the Black Beauty recommendation. It is coal sl*g. The coarse grade works best.
Edited by Dave (Mid-MI) - 26 Mar 2018 at 11:10am |
jerbob
Posted: 26 Mar 2018 at 11:35am |
Thank you Dave. Brought a few bags from Tractor Supply andvwill check it out.
You in Michigan? I'm in Jackson. |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42263 |
Posted: 27 Mar 2018 at 8:37am |
Use to process the Black Beauty / Back Diamond blast media as well as silica sand about 2 miles from here -
The black media was COAL sl*g - coal is ground into fine powder / chunks then blown into power plant boiler to make electricity. The result is the black pellets left over after combustion, the ash is separated as posolone for concrete additive and the rest is graded to size for blasting . The silica sand was mined , washed , graded , dried and used for sand blasting as well as molding sand for foundry casting of metals . All was well until power plant switched to natural gas - then next the silica sand was found to be good for frack sand - 4 years of 24/7 mining and hauling and hill they were mining is mostly reduced to waist piles - area ready to be turned into houses or apartment buildings - as suburb creeps out this way . Soda blasting does work good and soda comes in different grades and types also baking soda texture is one but there are other grades that have sharp crystal form that would work good also |
jerbob
Posted: 27 Mar 2018 at 3:51pm |
Very interesting stuff here Coke. Thank you. Its 48 in Michigan and raining but this weekend in the 50's and the power washer and sand blast kit coming out. My power washer uses syphon method so Im interested in how much this think will blast. My power is a hot water/ steam and puts out 4,000psi and good GPM. Brand name of my washer is a Shark. It really does a great job with the hot water and high pressure so Im thinking if this sand blast kit works half as good as they show, it should be cleaner using water to drive the media. Will take pics and let Y'all know. Or video. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55261 |
Posted: 27 Mar 2018 at 6:03pm |
All these years on here, never realized why the site censors the word sl*g... sl ag, s lag, sla g!
