What makes a WD pop when throttle is closed?
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Topic: What makes a WD pop when throttle is closed?
    Posted: 14 Mar 2026 at 8:39pm
I know that the WDs always pop when you close the throttle quickly. Mine really pops. Loud - 2 or 3 bangs.
Magneto ignition. I have timed by ear - don't have a timing light. Also aftermarket marvel carb with adjustable main jet.
If I got found a light, where is the timing mark?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 9:01pm
you dont need a light.. You can static time it at TDC on #1 cylinder.... When started, the MAG impulse will change that to the FIRE mark..
i think your timing mark is the set screw on the front pulley, pointed straight down... but others will confirm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 10:45pm
Mostly the idle jet setting I think. POP BOOM POP! Yep they are great!
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2026 at 1:20pm
To me sounds like it’s tuned correctly.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2026 at 6:44pm
My WD45 does the same. Means it is running properly but I have no idea why! I think maybe because the exhaust is so short and straight thru. No back pressure. Automotive engine with just headers on it has same tendency.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2026 at 7:41pm
remember when cars had carburators ?     what they sounded like when they was going down the hiway and they let all the way of the gas
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 12:18am
And turning the key off going down a hill with a big truck and then turning it back on.Big bang
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 5:35am
It is a lot of things changing all at once. Throttle closing quickly lowers volume and temp and the raises the percentage of unburned fuel in exhaust flow through muffler. Fresh air with oxygen gets drawn in and causes the pop (explosion and flame). If you slowly close the throttle you control the rate of these changes and it stops the sudden rush of cool air full of oxygen so no sudden explosion. My WD has some exhaust leaks at the manifold. At level throttle mid RPMs with not much load it puts out a lot of blue flares with not much pop only visible after sundown.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 12:30pm
Yup.
Followed by a continuous loud roar from the split muffler!
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 12:46pm
Although I'm not an expert and I agree with all others about them (and a lot of other old carbureted equipment with primitive ignition advance) often popping, it doesn't hurt to check the exhaust valve lash and (most significantly) the seals around the throttle & choke plate shafts going into the carb. Those are two aspects that can cause a heck of a lot of popping when idling down or when the engine is being pushed/over-sped by a heavy load.
At our Northern farm, one of the hills between on the road between our hayfields and the farm is very steep (almost dangerously steep). Back in the day when we did more square bales and were running the roads several times with a heavy load of square behind and old tractor, they'd often popping as you idled down towards that hill, and even more so as the load was pushing against the engine going down that hill. You never noticed it much in normal operation. If you kept the carbs shaft seals tight and exhaust valves set with a couple thou extra clearance, it would significantly reduce the amount of popping. The Massey 44 and Super W6 were always the worst offenders. Eventually the W6 got a valve job and it pretty much elminated popping.
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 6:36pm
"2 'cracks'--after WD throttle wide open--slam back to Idle--engine should make 2 'cracks' (backfire?) before coming to rest at idle.  Told to me by Jim Smith, salesman at Smith Implement Co., Arlington, Ohio, as told to him by Eldon Bash, old mechanic at said dealership in 2009.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 7:09pm
Arlington Ohio……..used to drive through there all the time. Pretty little farm town! Good old days for me.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 7:29pm
The dealership was on the East side of Main Street (US Route 68) just north of Corbin Bros. Chevrolet garage.  Just about 10 miles south of Findlay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 6:53am
I can picture the Chevy garage. It’s been a minute! I’ve stopped at the restaurant on the east side of 68 on the north side of town that looks like a big house. Think it changed hands a couple times?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 7:00am
US 68 to Kenton, then OH 31 to Marysville, then to Columbus etc. I always thought that was some beautiful farm country!
Brian G. NY View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 4:38pm
HudCo, yes I remember those days well!
On one of my flathead V-8 Fords with duals and glasspacks, I ran an extension of the  vacuum line into the cab with a on/off valve.
Open the valve when going down a long hill and those glasspacks "rapped" really nice.
Oh, the things kids will do for fun!!
Another of my favorite exhaust sounds is a WD-45 wide open under a good load!
They also "rap" real nice going down hill with a good load behind them.
I was always a Ford guy but the sound of a 6 cyl Chevy with a Fenton split header and a set of "Smitty's" is one of the fondest memories of my early driving years.
Wow.....I think I kinda got off the beaten path just a little.
Sorry, us old pharts sometimes  just have to get "lost in the fifties" once in a while.
Edited by Brian G. NY - 20 Mar 2026 at 4:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:29am
Did I hear a request?Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 14 minutes ago at 11:14am
That is a great sound as well!!
