What makes a WD pop when throttle is closed? |
kevin LA-CA
Joined: 12 Sep 2009 Location: california Points: 80 |
Topic: What makes a WD pop when throttle is closed?Posted: 13 hours 9 minutes ago at 8:39pm |
I know that the WDs always pop when you close the throttle quickly. Mine really pops. Loud - 2 or 3 bangs.
Magneto ignition. I have timed by ear - don't have a timing light. Also aftermarket marvel carb with adjustable main jet. If I got found a light, where is the timing mark? |
Joined: 11 Sep 2009 Location: illinois Points: 90500 |
Posted: 12 hours 47 minutes ago at 9:01pm |
you dont need a light.. You can static time it at TDC on #1 cylinder.... When started, the MAG impulse will change that to the FIRE mark..
i think your timing mark is the set screw on the front pulley, pointed straight down... but others will confirm.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8946 |
Posted: 11 hours 3 minutes ago at 10:45pm |
Mostly the idle jet setting I think. POP BOOM POP! Yep they are great!
