What makes a WD pop when throttle is closed?
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Topic: What makes a WD pop when throttle is closed?
    Posted: 14 Mar 2026 at 8:05pm
I know that the WDs always pop when you close the throttle quickly. Mine really pops. Loud - 2 or 3 bangs.
Magneto ignition. I have timed by ear - don't have a timing light. Also aftermarket marvel carb with adjustable main jet.
If I got found a light, where is the timing mark?
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2026 at 6:57pm
I see you have the same post twice.  If you have a light you time it laying on your back. Take off the inspection cover for the clutch. Clean things up. You will see marks on the flywheel.  Time it to the “F” mark at 1/2 throttle or more.  That is 24 degrees if I remember correctly. You will need 2 people who kind of know what they are doing! You can use the light, other person to play with the distributor.  Or if you have no help you can do it yourself - may have to get up and down a few times. Smile
The “F” means fire.
Edited by Ed (Ont) - 15 Mar 2026 at 6:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 60 minutes ago at 11:17am
Were you able to get a timing light and check the timing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 41 minutes ago at 9:36pm
Hi Ed
I was following my other posting. Oops.
I will have to crawl under the WD and try this weekend. On my own so will have to do the dance...
I will let you know the results.
Kevin
This page was generated in 0.373 seconds.
