What machine used this part? |
| Author | ||
TomYaz
Topic: What machine used this part?Posted: 09 Jan 2021 at 6:06pm |
Number in casting is SG-252L...
![]() Very similar to something used on the Rotobaler. A have also larger version with a better number that was used on moldboard plow (??? thats what the master parts catalog says!!) and a Field cultivator..... |
| Sponsored Links | ||
Stan R
Posted: 09 Jan 2021 at 6:20pm |
TomYaz
Posted: 09 Jan 2021 at 6:35pm |
I searchd to and cam up with a archived snippet saying "Don't know what kind it is has # LTP 180 on hub & another # SG252L " The link to that snippet is gone.. I bet it is referencing that same pic and it goes on that plow.. But what the heck would that part be doing on that plow??? |
TomYaz
Posted: 09 Jan 2021 at 6:36pm |
But then again, I have a larger version of the part that my book says goes on a plow!!
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 09 Jan 2021 at 6:43pm |
Part of the trip lift
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
TomYaz
Posted: 09 Jan 2021 at 6:54pm |
I see....thats a big hunk of metal for that! Thanks All!
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 09 Jan 2021 at 11:22pm |
yeah, it's kind of like a ratchet. As the wheel turns, a piece of cog slides into the path of the cut outs and then you can see where it would push against the lip until it had to slip into the next one. I hope that explanation works for you?
Mikez
Posted: 09 Jan 2021 at 11:31pm |
what’s the other side look like Tom
Fred in Pa
Posted: 10 Jan 2021 at 7:45am |
Mike , Just flat n round.
DWC17
Posted: 10 Jan 2021 at 8:35am |
Tom, from what I see in my plow book and on my plow, part # SG252L is the inner clutch on a #1 plow. The center hole should be 1 1/2" diameter for the axle to go through. The # N-297A is the hub cap for the same plow. # LTP-180 is a clutch throw out arm on a # 1 plow. You said you have another piece that is larger and if the number is SG 257L then it is the inner clutch for a #2 plow. The hole in the larger piece would have to be a larger diameter for the larger axle. I am looking for part # 300729 which is the outer clutch for a #2 plow. It would have 2 ears stick out 180 degrees from one another.
Dan
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2338 |
Posted: 10 Jan 2021 at 8:36am |
like Fred said, part of lift, plow or cultivator or similar.
TomYaz
Posted: 10 Jan 2021 at 12:25pm |
ok guys, the flip side per request
This should answer some guess... The bigger part is part number 315024 ![]() |
TomYaz
Posted: 10 Jan 2021 at 1:02pm |
BTW I have the LTP-180 too.
Fred in Pa
Posted: 10 Jan 2021 at 1:25pm |
TomYaz
Posted: 10 Jan 2021 at 1:30pm |
Thanks Fred !
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Posted: 10 Jan 2021 at 2:00pm |
My hernia hurts just THINKING what them 'things' weigh......
1947WC
Joined: 11 Dec 2015 Location: Wisconsin Points: 214 |
Posted: 10 Jan 2021 at 3:28pm |
Maybe off a wc?
Fred in Pa
Posted: 10 Jan 2021 at 3:52pm |
If you read all above ,its a plow part , Jay what makes u think these small parts weight so much. LOL
Here is Plow my parts in above picture came off of . ![]() Edited by Fred in Pa - 10 Jan 2021 at 4:07pm |
jaybmiller
Posted: 10 Jan 2021 at 5:15pm |
re: Jay what makes u think these small parts weight so much. maybe I'm just getting old......sigh.... I STILL can't find my battery carrying handle gizmo, it HAS to be IN the garage,it ws there when I put 2 batteries in the forklift a month ago maybe I'm just getting old......sigh....sigh....um... Jay
