what kind of allis do you have?
 Post Reply Post Reply Page  <1 234
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 8:39pm
1946WP - Just wondered if you knew of a trick to let your Farmhand down slow. With the loader raised, shut off the PTO. You will need to be out of gear as well. Turn the hand lever ahead as if you were going to raise. With the lever still ahead pull it out toward you. The oil runs backward through the valve and runs the pump and PTO backward as well, and the tractor gears make the loader come down slow.
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 8:41pm
My only AC is a 48 WD with a Freeman loader. I was informed it will be my only tractor until my wife gets her utv. Seems fair.
Brian
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 8:55pm
I currently own a 1981 7060 and 1973 185.In the past my Grandfather owned a U and UC,WD.My Dad and I owned a D17,170,200,7000.8050.
Kip[NY] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip[NY] Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 9:00pm
Some great looking tractors here, guys.  We have just one.  She's worn these colors since she entered the family.  The original owner traded her in, and to probably make her more attractive for re-sale, the A-C dealer repainted her in this scheme.  Not original but we think she looks just fine.     Kip
1959 D-14 SN/21089 "Martha"
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 9:05pm
I like the yellow ones.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 10:16pm
'59 D14. Owned since 1981. I am the second owner. Cousin bought it new here at local dealer. Restored in '06  but still has to work hard. Installed Char-Lynn power steering when restored. It smells kinda bad right now from putting out hay.JP
Edited by Jack(Ky) - 14 Dec 2010 at 10:17pm
acdave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdave63 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 10:54pm
i have a d 17 series 4 wf 3 pt very handy little tractor
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 7:02am
51 WD WF PS 3 point
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 10:39am
4w220, 8070fwd, 8050, 7030, 190XT III, 185, D21II, D17D, D17, D15DII, D15I, D14, D12, D10III, B, 444 baler, 2600 disc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 10:40am
Forgot F, M2 combine, 330 planter
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 10:50am
Have had a WD, All Crop 72, now only a 170, and a JD 40 Crawler for the deep snow.
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 1:06pm
1955 WD45
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 6:37pm
Listed below.
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 8:34pm
'57 D-14, 60? D-17 IV, and AGCO LT75 4x4 if that one counts.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 8:38pm
Edited by Claus - 15 Dec 2010 at 9:26pm
Lynn TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 6:11am
185 bought new, 6080, 8010, 7040
Fogot the F2 Gleaner
