What is your winter project?
 Post Reply Post Reply Page  <123>
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 8:03pm
I'm hoping to get a little done on my B if it warms up some over Christmas break (yeah right). Other than that I'm going to pick up a Gravely walk behind that needs a little work.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:20pm
   I'm sure that you have heard the term 10# sh%$# into a 5# bag,   Put a 20'x42' loft in my 60'x100' storage barn that was over filled, now tthe tricky part starts, trying to move the tractor parts out of the workshops, so we can think about restoring tractors.   Life is GOOD!!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:39pm
I've already got plenty on the go.  6 rear tractor rims to sandblast, prime, and paint.  Put new rubber on said rims, and put back on 59 D14, 15 II and 175.  Have to give the recently acquired D15 some TLC (cosmetic and mechanical).  What started as a new wiring harness on the 175 has evolved into a total restoration - no major problem.  It is already in good mechanical shape - needs lots of cosmetic work.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:40pm
Need to replace the flywheel ring gear on my C. Want to pick up and start rehab on dads'(grandads) C, and just got a #4 plow to get ready for spring. Feel pretty sure that none of that will get completely finished, but all of it will get started.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:47pm
Feed cows, build fence, build a lot to catch cows, finish wiring the grain bin, cut up some scrap metal with the new torch, and find time for these projects.
If fishing is a sport your looking at an athlete
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 10:12pm
I have to fix the fuel gage on the 175D that quit last summer....problem is the hood, muffler and whatever has to come off to get to it. I also have to rebuild the pivot points on the JD MX8 mower that the 3pt is slowly wearing out (poor design). Then I have 30 tines to replace on the Howard rotovator as well as a bunch on the Northwest rotovator, then about 10,000 other projects if I get time....YAWN
ALLIS EXPRESS!
This year:
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 1:19am
shhhhhh....ya'll my ole lady oppps...i mean my loving wife! might be listening!! i don't need anymore projects right now! i do gotta finish the well house, and then i will probably start cleaning out the basement (AGAIN) that flooded last spring! gotta hook up the wood furnace, down there as i'm gonna burn everything i can instead of hauling it all upstairs and outside! ie...furniture/carpet/etc. it got really deep down there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 1:21am
i did want to put a divider curtain in the shop so it would be easier to heat...then i could hide in there from you know who!! lol
SteveC (NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC (NS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 6:31am
 It's 10°C , 50°F today so I'm gonna swap the hydraulic pump on the CA and mount the snowblower and it's chute controls on it. I've been struggling too long with it on the B.
Hopefully the slower reverse and the hand clutch will make it a bit more efficient
Steve
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 6:48am
Where to start !!!! Finish getting 2 21's runnning, l;eft rear brake froze up on 220, mount firrent tires on back and switch out fronts, change tires on front and  back of Black Face 7030 and straight pipe, bring in donor 21 to make into a Industail 21 and pull motor out .Put that motor into Tricycle 21 and take tricycle motor out and give to KevininWA. That motor with the Industrail motor I got from Dale Hardke, when then go into the Industrail and start restoring that. Once that is started, I hope to get done by early to mid season my Hot Farm 21 with the A pump on the track for its first pass after 2 years.  This all makes sence to me so I better eat some breakfast and work out in the shop before I Go to regular work at 6:30.
Great topic
Take care, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 6:50am
Sorry for the spelling. I get in a hurry. I get this from my late Dad.
Got to go !!!
Darryl
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 7:26am
Just finished the third bedroom!  Now I gotta do the hallway, then install all the new doors, 4 regular and 2 bifold.  Then it's on to . . . . . ..
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:26am
Finish straightening out wiring in house, (almost complete) add 26X28 garage on house (spring project)
@farm, change fluids and tune up G, get all cultivators moving freely and set up correcty (finally have 3 sets for 2 tractors, should be enough to get two sets working correctly)
Rehab brakes on G, and possibly Clutch...
@ parent's farm, split IH 884 and put in new TA. also figure out why diff lock is stuck in OFF position, and get dummy lights to work again.. (mostly a job for the farm manager)
Then perhapse get to the work my truck and car both need..
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:39am
Becoming more proficient at Solitaire, recovering from heniated umbilicus repair(broke belly button) reading John Griisham, Tom Clancy, and any others that get in my path, dreaming of getting my dad's 37 WC that he bought new back together, finally getting started on my 53 WD that I bought for the tires bout 10 years ago (like to age my projects like a fine wine), want to make a plow tractor out of it (don't see why it wouldn't be able to pull a 4-16 snap coupler at Rantoul, Il. or Lafayette, In, after all Marion Klutzke pulls 3 bottoms with his WC) cleaning out the shop so I can get more in it than 1 tractor, it just seems i'm to busy to get anything done. Wonder if procrastination plays in here somewhere? Oh, yeah, glad I'm 69 years old, and past having new children, cause as busy as I am I'd probably have to hire help! And then there is that get up and go to work thing to get funds for all my needs.    Hmmmmm, maybe I do need help!  By the way, we are coming into the good time of the liturgical year, the celebration of Jesus Christ's coming, may the advent of this celebration be a force of Peace in all of your lives.   Joe Klaus
Jamie (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:45am
Gotta work on the shifter and possibly some forks on the John Deere A. May do some body work and replace a few gaskets on the John Deere H. If I started right now, it would take me until 4th of July to clean up the shop. The possibilties are endless.
Just when I thought I was finishing my "honey-do-list", she turned the page!!!
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 10:00am
My 2000 F350 6speed crewcab truck lost compression on its 7.3 diesel engine at 274,000 miles.  I am not upset as most of those miles have been pulling a goosneck trailer with GVWR of 25K.  I found a 96' cummins 5.9 12 valve out of a Dodge to swap into it.  Hope to have it done before end of 2010.  I will follow-up with some photos as it permits.
Curt-Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt-Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:12am
Have to get corn planter ready for spring and then I can work on the 2 72 allcrops I have in the shop. One will need major work and the other only a few items repaired and checked and then paint. Need them to run clover with next summer. Put on the drapers on the 66 so I can run some wheat for fun next july. Love those old all crops.
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 2:09pm
Finishing up the CA (put the right brake band in, clean up the fender bracket and paint everything)
John R. Mrotek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John R. Mrotek Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 6:16pm
Many of you have either seen the double G that I built or pictures of it.
Well now I am really into buiding a 1/2 scale double G. I most of the enginering's done Now I need to put it together, with the new sheet metal that I make out of fiberglassing it.
However I have just had my knee replaced so it may be a month or more before I become, really activate again.
Johh
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 7:43pm
wish I had a warm shop!
Charlie
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 7:50pm
John, I haven't seen a double G, could you post a picture?
Ken(Bell.Wa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(Bell.Wa) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 7:55pm
The same project that didn't get done last winter 37 A it has been in two peices for over a year, also get heat in the shop. It will be finished for the 2013 GOTO Lynden, WA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John R. Mrotek Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 1:20pm
I am building a half scale double G. The first double G I built I took the front wheels
off of two G's.
This one will have 16 inch wheels front and back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 9:59pm
   Hello John Mortek!!   I know that you have enough desire to get moving with your "G" project,     BUT  make sure that you do ALL and MORE physical therpy.  Been there done that!!
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 4:53am
Good luck John. Make sure you have the new knee working OK before getting too involved in heavy labor. I'm sure it will be a knockout once complete.God Bless. Merry Christmas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John R. Mrotek Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 3:38pm
I am doing a half scale G with 16inch wheels, this is a double G like the
big one or real one that I built a couple of years ago.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 4:25pm
Well as of now I've got a WD-45 in the shop to get it in good working order, engine/power steering, front end is loose etc.  Also have got an A-C forklift in for an overhaul.  Outside awaiting in a snow drift is a WD for a tune up, and a WD-45 for a Paint job.  D-17 Diesel needs to get on the list for paint too, but most likely won't be done until spring or summer.  My 180 needs the PTO fixed too, as well as the front end needs some attention, and new front tires.  Looks like I better get busy.  Here are a few pics.  Don't mind the JD in the Pic, it is not ours, its only in there to be worked on.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 4:30pm
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 9:28pm
Learning the ins & outs of flying to South America.
Scott
Sunrise over the Amazon - First trip to Rio de Janerio, Brazil
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 2:08pm
Been using the CA with the snowblower on the back and it's better than the B because of the hand clutch but the reverse speed is just about as fast as the B (too fast).
I'm sorta leaning toward mounting it on the front.
I know I'm gonna need to reverse the drive direction and I'd like to do it with gears and increase the blower speed from the 540 rpm. I have a pair of helical gears that are 60T & 75T which would give me 675 rpm at pto  speed. Any thoughts.
Is there anyway I can find some of the old posts from guys who've  front mounted a blower on the CA?
