what is your choice of tough paint?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: what is your choice of tough paint?
    Posted: 15 Aug 2016 at 11:29am
Hello All,
Just looking for some input. I am looking for a tough paint that does not require a clear coat. What are you using?
Is polyurethane the toughest paint?
Thanks
Pastor Mike in Iowa
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 11:42am
Single stage means no clear coat, so that's what you want. I used acrylic enamel with harder on mine. It's looks good, but seems to chip easier than I'd like. When it chips you can see the primer underneath. I used self etching primer, then sealer, then paint. I have a theory that the sealer actually chips off and takes the paint with it, but I don't know if that's true.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 2:37pm
I like Nason Ful Thane single stage
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 7:01pm
Bare metal with rust.   No matter what you do you can't mess it up! LOL
timr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timr Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 9:52pm
Probably can't go wrong with ppg deltron with dp50 epoxy primer under it plus they have good allis codes.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 5:29am
I use urethane enamel with the proper hardener. I've used it on my last 3 tractors, I'd use it again.
I also prime with a self etching primer as the first coat, then use a sandable primer, followed by a sealer before painting.
Works well.
Oh yeah, I get the paint at NAPA. They too have all the proper paint codes.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 6:14am
I have used Omni single stage urethane on several and like the gloss and durability of the paint. It is a PPG product and as said they have the proper codes.    It is a lower level auto paint price wise and with primer, sealer, top coat, activator,and reducer it will cost in the $700 range to end up with a good paint job that will last your lifetime.
This page was generated in 0.223 seconds.
