What is this bracket?
Message Reverse Sort Order
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Topic: What is this bracket?
    Posted: 05 Feb 2011 at 11:10pm
This piece is used for locking the top link in place so it doesn't slide back and forth.  There should be 2 of them, one for both sides of the toplink.  It is home made, I have 2 of them.  They just squeeze down on the rock shaft to keep it from sliding.
That is how mine is set up too.
David Gibson
http://www.darkecountysteam.com
1956 WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 10:23pm
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 12:08pm
It looks like a brace attachment for something that moves with the hydralic arms, maybe a post hole digger or lift arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 11:59am
I was kind of thinking the same thing Brian. That bracket looks like it has been there a long time from the condition of the paint and the square nut. Same situation here, I don't know what it is either.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 11:56am
I've seen a few of the homemade toplink brackets; I even made one for my own WD.
However, unless this has been cut off (which it doesn't look like it has been) there is no place to attach the end of the toplink. That looks like a typical square head setscrew used on many A-C things but why would it be there since the toplink bracket has to be free to move on the shaft. Also.....i have a clamp on each side of my bracket to keep it centered.  The only thing I see that would keep this bracket "located" is that setscrew.
I know..........I posed a lot of questions but did not answer the question.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 9:51am
Just like the others said....top link bracket.
Edited by David Gibson (OH) - 05 Feb 2011 at 9:51am
David Gibson
1956 WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 9:27am
I have the same thing but longer on my WD45.Like others have said some type of top link.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 9:21am
Looks like a toplink bracket with half of it cut off...
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 8:55am
Looks like part of a top link bracket to me.
AaronSEIA
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 8:25am
What is this bracket on the cross piece of the lift arms on my 45? It looks like its supposed to be there, but doesnt look like it doesnt do anything.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
This page was generated in 0.127 seconds.
