What is the true hp of my 200? |
DanM
Topic: What is the true hp of my 200?Posted: 03 Feb 2010 at 8:53pm |
I have a 1975 model 200. I have seen the 200's listed as both 93 and 107 hp. I will say that for a "100 hp" tractor the ponies are on the small side. I also have a 1987 White 2-110 that is supposed to put out 108 hp but turned 130 hp on the dyno. It outpulls my 200 easily. The AC has never been dynoed so I am wondering what do you folks consider the true hp rating of a 200 to be? Dan |
JR
Joined: 15 Sep 2009 Location: North West AR Points: 12 |
Posted: 03 Feb 2010 at 9:06pm |
200's were rated the same as the 190XTD 93.64 according to Norm Swinford's book.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5159 |
Posted: 03 Feb 2010 at 9:23pm |
190XT's were rated when they first came out in 65, at 93.64HP i think. the later pump specs called for 3 or 4 more cc's of fuel output at rated speed, so all but the very early tractors should actually put out right about 100HP. The pump spec fro a 200, however, should result in about 105HP. This is if everything is set at spec, though few are. Ed.
DanM
Posted: 04 Feb 2010 at 10:43pm |
Thanks for the info guys.
Dan
Dans 7080
Posted: 05 Feb 2010 at 1:10am |
the 200 was sold on the 93hp rating. Most of them were "turnd up" a little bit and running to match the replacement 7000. The one i own turns 110hp on the dyno, very close to the 7000 rating of 106hp.
