What is the true hp of my 200?
DanM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanM Quote  Post ReplyReply Direct Link To This Post Topic: What is the true hp of my 200?
    Posted: 03 Feb 2010 at 8:53pm
I have a 1975 model 200.  I have seen the 200's listed as both 93 and 107 hp.  I will say that for a "100 hp" tractor the ponies are on the small side.  I also have a 1987 White 2-110 that is supposed to put out 108 hp but turned 130 hp on the dyno.  It outpulls my 200 easily.  The AC has never been dynoed so I am wondering what do you folks consider the true hp rating of a 200 to be?
Dan
JR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 9:06pm
200's were rated the same as the 190XTD 93.64 according to Norm Swinford's book.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 9:23pm
190XT's were rated when they first came out in 65, at 93.64HP i think. the later pump specs called for 3 or 4 more cc's of fuel output at rated speed, so all but the very early tractors should actually put out right about 100HP. The pump spec fro a 200, however, should result in about 105HP. This is if everything is set at spec, though few are. Ed.
DanM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 10:43pm
Thanks for the info guys.
Dan
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 1:10am
the 200 was sold on the 93hp rating. Most of them were "turnd up" a little bit and running to match the replacement 7000. The one i own turns 110hp on the dyno, very close to the 7000 rating of 106hp.
