What is the best noncorrosive tire ballast?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: What is the best noncorrosive tire ballast?
    Posted: 09 Apr 2023 at 8:48pm
What is the best noncorrosive tire ballast?  I find all sorts of weird stuff...like beet juice...but water is 'corrosive' also...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 9:01pm
search = Beet juice is a recent addition to liquid ballast choices. The advantages of beet juice are it is nontoxic and non-corrosive to wheels. It is freeze-resistant down to minus 35 F. Beet juice weighs about 11.0 pounds per gallon.
You can also use antifreeze mixed with water... but your below 8 pounds per gallon with that...
Calcium Chloride has the problem that it is a SALT and that corrodes metal when in contact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 9:03pm
or you can use steel wheel weights if you dont want anything INTERNAL..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 9:46pm
Methanol alcohol is what I use. Tracy
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 10:42pm
Common antifreeze (Ethylene Glycol) will work, but it's toxic... so a leak will poison pets.
Propylene Glycol (RV antifreeze) will work nicely, and it's non-toxic.
Both are mixed 50/50 for max freeze protection, but if you're in Texas, you really don't need full strength-  you could use water, and then just go to a 10% mix instead.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2023 at 11:14pm
Beet juice has been the best option I’ve tried but it’s starting to get a little pricey around here…
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 5:02am
CaCl2 is fine as long as you maintain your tubes.   Plus it’s natural. Have a leak wash it off with HOT water. I can safely say I handled more of it in my life than anyone on here and I don’t bat an eye at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 6:22am
CAST IRON, NO possibility of corrosion whatsoever. With any Calcium Chloride product it's not a question of IF but WHEN.
Also as you first mentioned any water based product will rust metal. At one time powdered lead was being put in tires, Although I'd guess you can't find anyone to do that today. Anything you put inside the tire will run to the ditch when you get a flat and you'll only have to pay again to add it back.
CAST IORN buy it once and you can easily remove it when not needed and put it back when you do.
Edited by PaulB - 10 Apr 2023 at 2:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 6:38am
Engineering is almost always a compromise. To get one thing, you might have to give up something else. Tire fluid changes the physical width of the tractor none and gains the most weight per area. Wheel weights are often in the way or make changing wheel tread more difficult. I still say a tire with proper amounts of fluid/air ride smoother than cast iron and air.  20+ years ago, when new FWA tractors got to 25+ MPH top speeds, we always had issues with bouncing on those large front single radial tires. So bad in fact, that you seldom could use the full top speed the bounce was that bad. We tried multiple air pressure changes and even reduced front suitcase weights to try to get the bounce problem in check. Eventually, out of desperation, I had my tire man install front fluid at 50% normal fill. We also removed front suitcase weights just enough to offset the increase of fluid weight, so the tractor weight was identical. Problem SOLVED !! No more bouncing at full road speed !!
Tbone95 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 6:43am
We use the beet juice, or the last fill was something made with corn, to adress what they is a valve stem issue with the beet stuff, though we didn't have much problem with that.
CaCl might be natural, but so is arsenic.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 9:37am
Probably easiest is windshield washer fluid. Drawback is it is not as heavy as some of the other stuff. If you can live with a bit less weight it is a good way to go.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 11:23am
RimGuard is an option but I havne't used it. Might be the same as Beet Juice, I"m not Sure. Currently I just have the old fluid in 2 of mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 11:26am
Yes, Rim Guard is the trade name for the beet stuff.
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 11:52am
I have beet juice in my tires and it has been great would not go back to CaCl2
Edited by Randy WI - 10 Apr 2023 at 11:53am
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 5:36pm
This comes from an old tire guy, me,. Beet juice is almost impossible to pump into or out of a tire when it gets below 20°F. Been there done it. If you can find a auto service shop that catches old antifreeze from the cars/trucks they work on, sometimes they will give it to you. Me, after pumping thousands of gallons of calcium, I would put new tubes in my tires and use calcium. Keep an extra core housing or two around and replace them when the core housings/valve cores get to seaping. They actually make stainless steel core housings with stainless valve cores installed to use when you have calcium in your tires. They used to be a little hard to find unless you were a professional tire repair man.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 6:20pm
I sandblasted and repainted the rear rims on my Series IV and was pondering the same thing and decided not to put anything in the new tubes. I got extremely fortunate and found the correct pie weights for a steal so after I paint them they will be going on. Ryan
Edited by Ryan Renko - 10 Apr 2023 at 6:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 8:47pm
At this point, I lean towards rim guard/beet juice.  I don't think it's an either/or thing though.  Ballast and when needed physical weights also.  I had already searched/researched and didn't like some of what I read, but you need the extra weight sometimes in a super light tractor with 24 inch rims like a CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 8:49pm
too bad your not closer to Illinois... I would make you a good deal on 55 gallons of glycol antifreeze !
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 9:18pm
I bought 100 gallons of windshield washer fluid on sale and loaded my AC  I-400 tired
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2023 at 9:50pm
Pie weights on a D-17 are 300 lbs per wheel. Full fluid (10 and 2 o'clock) is at least 500
 lbs inside the tire on a 16.9 x 28.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 7:15am
Not one of the CAs I have that I use for field use needs anything more that 1 CAST Iron weigh on each side and with only air in the tires. Now if you are using a front end loader on a CAs Cast iron weight behind the wheels is what you should have to counterbalance the weight added to the steering components of front axle.  A CA really doesn't really have a strong enough front end system for a front end loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 7:00pm
Seen quite a few with front end loaders...not real heavy duty ones, but useful nonetheless.
This page was generated in 0.087 seconds.
