What is realistic mileage for a Chevy 6.0 |
| Author | ||
Darwin W. Kurtz
Joined: 06 Apr 2010 Location: Westphalia, KS Points: 5689 |
Topic: What is realistic mileage for a Chevy 6.0Posted: 16 Oct 2023 at 7:30am |
it's in a 2002 Suburban, gas guage does not work, so we trip the odometer and put gas in every 200 miles. Mechanic says we will have to change the instrument panel which includes the odometer to get the gages to work, oil pressure gage has showed bad ever since we owned it, 6 or 7 years and 50K miles ago, he said pressure is fine, just gage. I don't want to have to mess with sending off for .... o think we will keep doing what we are doing until it all quits.
recalibrating odometer to get everything to work |
| Sponsored Links | ||
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 16 Oct 2023 at 7:53am |
wow I googled...2002 suburban instrument cluster, got 2 MILLION hits.... options... 1) I'd get another cluster from a you-pick-it-place..... 2) I'd also remove cluster and resolder the main connectors.... 3) you can buy refurbed units for $200-250 4) keep full gas can in trunk... as for mileage... fill tank to first 'click' at a pump, drive say 200 miles, refill at SAME pumo, 1st click. That will be a pretty good guage of MPG..
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 16 Oct 2023 at 8:59am |
well, if you drive 200 miles and then put in 20 gallons of gas... You can figure your getting 10 MPG... If you got a 30 gallon tank, you could probably get another 50 miles to the station.. I would not push it to the limit and try to run 29 gallons out of a 30 gallon tank !!
jaybmiller
Posted: 16 Oct 2023 at 9:55am |
or.. loan it to my brother who never puts gas INTO my rides....
Codger
Posted: 16 Oct 2023 at 11:19am |
Those instrument clusters are fragile but repair easily. Minute stress cracks in the solder runs can be found easily with a lighted magnifying glass.
That's All Folks!
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Posted: 16 Oct 2023 at 1:24pm |
Flat level ground 70 mph, 14mpg.
Pulling trailer with kubota side by side 70 mph 12 mpg Pulling 20ft camper to Utah 70 mph ,8 mpg 2005 Chevy hd with 6.0 gasser Edited by Pat the Plumber CIL - 17 Oct 2023 at 8:08pm |
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35679 |
Posted: 16 Oct 2023 at 2:01pm |
Sounds like my KW Pat!!!, Only it will not get 14 no load!
Mikez
Posted: 16 Oct 2023 at 2:17pm |
I don’t keep track but my little thing that show’s average mileage says 9.9. None of my dash works anymore. I’m hoping to get it fixed. Iv been told about half dozen different fixes though. One guy said there’s some kinda kit you can get that replaces resisters or something, he said it’s simple. Was going to try that first. But the little info thing works so I use the range for knowing when I need gas
DMiller
Posted: 16 Oct 2023 at 2:42pm |
Those sheet circuits always were a joke to deal with.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 17 Oct 2023 at 6:55pm |
Mines averaged 12 mpg for the last 650000 miles.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1125 |
Posted: 17 Oct 2023 at 8:02pm |
A lot depends on rear axle ratio
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 18 Oct 2023 at 8:09am |
Do you have too many zeros? That looks more like Big Truck miles.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 18 Oct 2023 at 11:13am |
10 to 12 MPG is the best I have done with the 6.0
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1619 |
Posted: 18 Oct 2023 at 7:43pm |
I concur, 10 to 12 mpg is all I could get too. It is a strong engine though for sure. I traded with 200,000 miles and never had an issue with the 6.0
Darwin W. Kurtz
Posted: 18 Oct 2023 at 7:46pm |
ours has 326 on it
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 18 Oct 2023 at 8:23pm |
My ‘95 Suburban w/TBI has averaged 12-13 mpg over it’s lifetime(211,000 mi). IIRC, 1995 was the last year for the TBI, then after EFI. 40 gallon fuel tank, if I’m not mistaken. 350 cu inch.
Edited by Lars(wi) - 18 Oct 2023 at 8:25pm |
Codger
Posted: 18 Oct 2023 at 9:13pm |
I had two 6.0 engines in 3/4 ton Chevy pickup trucks. 12mpg was on a good day and empty. No problems over my tenure with them and very reliable.
That's All Folks!
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 18 Oct 2023 at 11:05pm |
he who runs on the bottom half of the tank all the time will have more fuel pump failure than guys that run on the top half all the time
Codger
Posted: 19 Oct 2023 at 6:11am |
This is true and proven over many vehicles as the modern fuel tank is also the cooling medium for the pumping unit. Pumps have a longer service life when they are kept cooler than warm as is the scenario referenced.
That's All Folks!
Thad in AR.
Posted: 19 Oct 2023 at 9:27am |
No sir that is actual mileage. Had two water pumps and intake gaskets once. Transmission rebuilt at around 330000. She rattles on cool mornings but still runs strong. |
shameless dude
Posted: 20 Oct 2023 at 1:02am |
I also have an '02 burb, so far everything on the dash works, the 4x4 quit but still drives fine, I use it for a farm truck mostly, do take long drives sometimes. has over 150,000 miles on it now. they're not really worth anything for a trade in or to sell it, i'll keep it and drive it til one of us dies off! long drives we take the old lady's.....ooooops.....I mean the loving wifes Burb, it's a 2015. I don't really care on the mileage, it's better than walking! it heats good in winter and the a/c blows cold in summer, what more could a guy ask for?
Thad in AR.
Posted: 20 Oct 2023 at 3:27pm |
Is it push button 4x4? If so the switches are prone to fail. Can be had cheap online. |
shameless dude
Posted: 20 Oct 2023 at 11:14pm |
yeah Thad, it is push button, and it has been replaced, but that wasn't the problem, so I had a new (whatcha ma call it) installed in the transfer case, but something is wrong or broke inside the case and that new part won't fix it either. it still drives fine...just no 4x4. I can do without that as I own 7 other 4x4's I can use. i'll just drive this one til it dies or rusts away! lots of good parts on it yet in case I buy another like it.
