What is in your shed waiting to be worked on?
 Post Reply Post Reply Page  <123>
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 8:17pm
1951 CA#669 needs engine work. She's been patiently waiting since the spring of 07.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 8:29pm
My Gleaner needs a new set of bushings in an idler arm, a leak fixed and the rock door repaired.  I have the meters out of the 7000 planter and the fertilizer auger needs to be put back on the gravity wagon.  Been too darn cold!
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 8:43pm
Which shed?  LOL
RC-torn down, should keep me busy a couple years putting it back
Then have my Grandpa's Super H, my other Grandpa's WD & D 17 Series I; a D 14; a 41 JD B, MM Z, that should cover several coons' ages at my pace....
Thanks
acgman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acgman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 8:47pm
G High crop that I have wanted to restore for a couple of years. Dave.
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 8:48pm
35 allis wc, 39 RC , G, and a B, CA , U , WD45 ,WC vegetable special, 37 WC ,  I will stop there might be done in 2025 if I am lucky ...........
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 8:55pm
Put some 5 inch new chrome pipes on the 21s and mount some different tires on the tractors. Fix some leaks, put some new batteries in. Maybe do some stuff to the hot farm.
Take care, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 9:16pm
Reflight some augers on th F2.Get the 8070 engine back together before spring.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 9:46pm
What page of the book should we start on!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 9:48pm
What page of the book should we start on???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 9:50pm
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 10:09pm
The cruiser needs the most attention. It has to get a lot warmer first.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 10:30pm
Plenty here to choose from. I can pick from 3 Bs or 3 Cs and a 52 Willys Overland 4WD Jeep pickup. I hope by the time I'm 75 all I will have to do is  dust them off and start them once a month.
StanOhio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanOhio Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 11:09pm
Overhaul Farm-All 460D and maybe give an Earl Shied paint job, unstuck WD45, fix a tire on it and use it this year and give it a restore next winter, build a firewood prosesor, build a couple pumps.
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 9:22am
I have a WD-45 engine to rebuild, 3 rototillers to get running for this spring, anc continue the complete restore I started  5 years ago on a 1968 Chevelle SS(my first car).
Leonard
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 9:30am
I have a few leaks to fix on my 20-35 before I get it back out and I am getting ready to tear into my Isetta for a full restoration.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 9:52am
'45 WC needs brakes, '30 'U' , '29 Twin City, and '28 Hart Parr all waiting patiently in the shed for a turn in the shop but customer jobs such as Massey Harris GP and Minnie UDLX along with an Austin Healey taking up shop space!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 9:54am
Split 51;  you're really workin' both ends of the weight scale!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 11:38am
Nat's 66' Nova needs to be finished up once and for all, (a ten year project) then Ole' Hercule's my WC, is next in line, then the little smokey G goes on the resto block, and by that time, hopefully I'll have enough parts gathered for the newest project, my 27 T sedan Streetrod.  Those projects should keep me outta' trouble for a while. Coarse, I have the same problem as Dave(MA) gotta' finish the shop first!!  LOL!
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 11:55am
I have two trucks, a walk behind mower, a continental motor for a friend, a Mustang skidsteer and who know's what else parked IN FRONT of any orange colored projects. Our D-19 needs several cosmetic details and paint, that will probably be our next A-C project, if Im still alive when it gets to the front, LOL.
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 11:58am
My son and I are currently working on a 190 XT series 3, Hope to have completely finished by March 1.
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 12:29pm
14 allis tractors of my own I would like to get at ,69 mustang mack one ,1959 lyman wood boat I would like to put a fresh coat of paint on the 63 t bird But I have come to the conclusion that I probably won t live long enough to getthem all done but it will make a good auction some day
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 12:38pm
just finnishing up a D-19 D, put in a head gasket, went thru head, injectors,starter, generator,split tractor fixed high range,put in new pto seals, was transfering oil,new radiator, fixed power steeering leaks, 2 new 6 volt batt,new guages, rust repair on fenders and finally PPG paint. Next project is Dads 45 Deiesel, engine done, needs to go in tractor and get sum hours on it see what else needs to be done and then paint. Just ordered a car Rotissery for my 64 impala project, frame all done, body is next, so am stayin busy
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 2:27pm
Well I just gave away an original '55 CA for peanuts, last month the '48 G was hauled away for a next to nothing so all those coins and a few more bought an OK '59 D-14 that needs the op meter rebuilt and the PA rims freed up.Hard to get motivated without warm sunshine on the old body though.
Jay
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 2:44pm
We have in shed in the line waiting 1 WM crawler in parts 1 M crawler in pieces 1 WC wide front in pieces 1 orchard B and maybe another A  in the pipeline oh and the WF that is in Canada.
                   Dave and Mark Everett
J-WAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J-WAG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 3:07pm
well i got a 49 allis chalmers G that needs done, then i got a 36 fARMall F-12 that needs alot of work, and last a 50' Farmall M, that just needs paint
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 3:08pm
Dave get that A out of the shed .I am only coming over for a Vacation ,not work DETAIL. LOL
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 3:19pm
http://i38.photobucket.com/albums/e119/L7DCE/heatherspictures117.jpg
But im flying in EXPERTS to help with my restoration.......Check out the  reprobate on the left of the picture and the expert next to him..................
and Fred thinks hes coming for a REST and VACATION............WRONG!!!!!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 3:21pm
Tom IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 4:48pm
I have a CA engine in pieces while I gather parts. Then I can start on brakes and hand clutch. Then that (off color) Silver King stares at me every time I go in the shop.
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 5:12pm
lots of things!
1955 WD-45 with factory PS
