what is hd3 worth
1953 ib alabama View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953 ib alabama Quote  Post ReplyReply Direct Link To This Post Topic: what is hd3 worth
    Posted: 18 Mar 2010 at 8:21pm
while out today picking up a block for a g I came across this hd3 that I have been driving by for some time. To make along story short would like some advice as to the worth a if there is parts for this tractor. the son of the man that owned tractor said that the starter was breaking parts and that the left sprocket was trash.Do know if motor is locked or not .The man said that they pulled the tractor of with 6000 ford and used tractor appx. 4 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 8:25pm
I'd guess the pins and bushings are bad, that's why the sprocket is junk. If the engine is locked up it would be worth close to what unsorted scrap is worth.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 8:25pm
Might get better answers in the construction eq. area. Just a suggestion.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 8:28pm
a photo would help.  I would say about 1000 at most.
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 8:35pm
I bought a HD3 from my dad's neighbor last fall.  I paid 1800 for it.  It did not run, but the engine was loose.   I ended up having to have the injector pump gone through, 400, and am currently going through all the odds and ends.  Most of the coolant hoses were drycracked, so I have all that apart replacing those.  Two out of about a hundred hyd. hoses are cracked, that's apart.  One hyd ram is leaking.   Mine the undercarriage is like new.  It has only 1200 hours on the hourmeter and i know that my dad's neighbor bought it new and it was only used on the farm.  I don't know enough to tell you what yours is worth.  Parts are available, but can be expensive.  Kips estimate may be right.  If it were me, that would be the most I would pay for it, and if stuck maybe less.  If you go on the construction forum and search for HD3, there have been alot of posts lately.
This page was generated in 1.867 seconds.
