What is a “Tobacco Special” 180? |
59f100292
Topic: What is a “Tobacco Special” 180?Posted: 13 Aug 2019 at 12:42pm |
A 180 is for sale locally being advertised as a “tobacco special”. What is the TS? Some quick responses on Facebook came up with wider axles, lower, and slower gears. The one advertised doesn’t look any wider or lower in the pictures. How can I properly identify a TS?
frnkeore
Joined: 07 May 2019 Location: Southern Oregon Points: 362 |
Posted: 13 Aug 2019 at 1:13pm |
Do you know the size of the rear tires?
I'm thinking a high crop, with 38" rears. |
Frank
1959 D17 Series I #24001+, '59 D14 '55 & '59 Ford 850 & 861 Ferguson TO 35 Deluxe, Oliver 70 and 5 more. |
59f100292
Posted: 13 Aug 2019 at 2:41pm |
One comment on Facebook claimed they are 38” rears with tall front tires. Pics don’t appear to be 38s but there’s some debate on originality of the advertised tractor
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3594 |
Posted: 13 Aug 2019 at 10:50pm |
The 6000 series had a wide axle option - the only Tobacco word I remember..associated with tractors.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3158 |
Posted: 14 Aug 2019 at 2:54am |
Its been years ago but I have seen 180 and I think 185 tractors with the Tobacco Special decal on them at auctions in NC.Can't remember what tires they had.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54915 |
Posted: 14 Aug 2019 at 4:32am |
maybe just a clever way to explain that it smokes...
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 14 Aug 2019 at 7:14am |
I have seen them in NC. I thought they had tall front Spindles and 15.5x38's for working tobacco plants.
Edited by Charlie175 - 14 Aug 2019 at 7:32am |
Charlie
marzer
Joined: 08 Dec 2014 Location: Saginaw valley Points: 37 |
Posted: 14 Aug 2019 at 9:42am |
Mine has 15.5x38s. I didn't know it was special.
59f100292
Posted: 14 Aug 2019 at 10:26am |
This particular one advertised has 18.4-30 rear tires on 5 rib spin out rims. Front spindles appear to be normal in the pics but I don’t know what sort of a variation we are looking for. It also has a black dash cover, and a shallow front grill screen. Does this make it a late model or parts from a 185? Most seem do have an orange dash cover in pics? It also has a tall air cleaner stack above the hood, which seems to be hit or miss in pics of 180s.
Edited by 59f100292 - 14 Aug 2019 at 10:31am |
allisbred
Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Posted: 14 Aug 2019 at 10:48am |
Sounds like it could be a more desirable 185. Look at the housing just behind the frame to see what is stamped on it. 30” was more common on the 185’s, I didn’t know they were even available on a 180?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5223 |
Posted: 14 Aug 2019 at 12:06pm |
Marzer: Did your 190 take the short bus from the factory?🙀 |
marzer
Posted: 14 Aug 2019 at 12:44pm |
Looks close. Sounds the same. Just wish if could have sneaked out with console control...
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 14 Aug 2019 at 1:47pm |
My 180 came with 15.5/38 tears and 7.50 /20 fronts ordered to cultivate tomatoes
HagerAC
Posted: 2 hours 21 minutes ago at 8:50am |
We have one here pretty local to us that we worked on last winter that I would call it a tobacco special, not sure if they were ever labeled that, but I know I've seen others like this that were referred to as tobacco specials. It actually had a tag on it from Vause Implement which I believe is or was in North Carolina so it came from down south. It has 15.5-38 rears, tall front spindles and a canopy with a roof.
Acguywill
Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 181 |
Posted: 1 hour 37 minutes ago at 9:34am |
The guy I bought my first piece of land from had a tobacco special. We are a very long drive from a tobacco field and I am not sure how or why it ended up in this part of the country. I don't remember much about it other than it had been beaten regularly and had the tobacco special decal on it somewhere. This was 35 years ago. Possibly was ordered for use on a potato farm originally or to pull a pea harverter. That's about the only reason I can think of for a higher clearance tractor here at that time.
