What Is A 21000 MK II
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: What Is A 21000 MK II
    Posted: 10 Jan 2024 at 7:41pm
There is one on an Oshkosh truck that powers the snow blower. I believe it’s on Sullivan auctions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 8:26pm
21000 was a 844 cubic inch straight six cylinder with a turbo charger.  One use was in the 21C Dozer at 325 HP ....... similar in other applications... If you wanted MORE HP, you changed it to a 25000 which was the same engine with an intercooler to lower the air inlet temp after the turbo....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2024 at 8:29pm
Mralice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mralice Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 4:26am
Could a 21000 be used in place of a cat D333
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 5:52am
Cat D-333 is the older version of the 3306 family and are 638 cubic inches. I doubt that you'd be able to install an AC 844 cube engine where a 638 cube engine goes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 7:59am
Ill say one thing - they are a hunk of cast or whatever  iron! Whew heavy built! Seems they were easy to get power out of them ,,
This page was generated in 0.039 seconds.
