What Holds A WD Shift Lever Down?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: What Holds A WD Shift Lever Down?
    Posted: 23 Oct 2016 at 7:05am
Had to get dads WD out of second yesterday with a screwdriver. Went to pull the shifter and there was no snap ring. Just a thin metal washer with a lip on it. Parts book shows a washer and snap ring. Aftermarket parts show a snap ring and what looks to be a pretty thick round washer that looks like a metal o ring. What should be holding it all down?
AaronSEIA
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 7:34am
Hmmmm - snap rings need a groove to rest in else they don't do more than serve as an ornament! I'll take a look......
Aaron, on my WD45 the top of the tower is 'indented' a bit for about 1/4" down (looking down from above the tranny cover) creating a lip at the top of the tower. The snap ring sits just below the indentation or lip. Looking at my Parts catalog, I'm seeing both the straight and curved shifter trannys with the same arrangement. Having looked at the actual tranny, I can see the tower lip described above. Hopefully this helps
Dave
Edited by Dave(inMA) - 23 Oct 2016 at 8:03am
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 8:00am
Yeah, that is how they work. Just not sure about this thin cup washer when the pictures show an oring style metal washer and snap ring. I dont feel like pulling his WD45 apart to see what's under it.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 8:04am
Ah...perhaps someone replaced the original washer with the current one.....
WC, CA, D14, WD45
This page was generated in 0.057 seconds.
