What gas to run
Putnamd17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Topic: What gas to run
    Posted: 04 Nov 2025 at 8:49pm
I recently went through and resealed the engine on my d17 gasser and was wondering what fuel everyone runs in these older tractors or what additives they put in the tank. It won’t get ran very much just a little garden work but it’s restored now so I want to take care of it thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2025 at 8:54pm
Best thing to do is to turn the petcock valve at the fuel bowl off, and let the tractor run out of gas at the carb(for long term storage).  That way whatever gas you use isn't in the carb to go bad...Wink
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2025 at 9:04pm
You can also use SeaFoam in premium, ethanol free gas, stuff I get is good up to two years it says on the bottle.
But couple of garden tractors I have that sit most of the time (gas with SeaFoam is older than 2 years) will still run pretty much full power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2025 at 9:12pm
Illinois switched to 10% ethanol prior to 1989... I bought a new F250 that year.. EVERYTHING i have, truc, car, mower, weedeater, chainsaw, several tractors ,  4 wheelers have all been running 10% for 35 years..
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2025 at 11:19pm
If it sits around much go with non ethanol
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 1:34am
Others will definitely disagree, but here's my own opinion (reply copied from one I wrote a few days ago on another forum):
I used to drain and run dry all my tractors and small engines. I then found that I had better luck just putting a good dose of stabilizer in the tank, running it for a bit to get some stabilizer through the system, and keeping the tank full to prevent condensation. Back when I ran them dry, it seemed like one out of every 10 engines or so would need a carb cleaning and/or float un-sticking the next year. I think probably more so with tractors that have cast carb bowls and bare steel lines, where running them dry means the steel/cast is exposed to air and might rust. Better to keep them full of fuel in my opinion. Never had a problem since I started keeping them full. I just fired up a gasser Fordson yesterday that hadn't been ran since November 2023. It fired up instantly, and went to work on the chipper just dandy. Nothing but regular E10 fuel and a good dose of stabilizer in the tank.
I also now use regular fuel and don't worry about the ethanol content. I've completely flip-flopped on this one. I used to be obsessive about buying premium with no ethanol content. But now I just buy whatever regular gas is closest, and put a good dose of that Lucas upper cylinder lubricant & stabilizer combo in all of my fuel. If I know I'm going to be adding more fuel before winter, I use a shot of two-stroke oil rather than the Lucas stuff, because I just want the lubricity and don't need the stabilizer. Haven't noticed any difference from premium - Neither with my old gassers that get the heck worked out of them (Allis 180 on the round-baler and Ford logging units) nor with the gasser toys (Fordsons, Cockshutts, W6, etc.) that see minimal use and sit for months at a time.
If you let a lot of moisture accumulate in your tanks there is a 'slight' concern about fuels with ethanol in them separating/stratifying if they sit for an extended period. But you have to have a heck of a lot of condensation/moisture accumulate for that to happen, and also have them sit for a heck of a long time. Even at our Southern farm in the Great Lakes region with constant high humidity and heavy condensation on every surface every morning for most of the year, it's never been a concern. Marine engines would be about the only time I'd be concerned about it.
I've also flip-flopped in my beliefs and I'm now a fan of ethanol fuel: Commodity crop prices are so low that we need all the help/markets we can get for our crops. And ethanol/bio production is a huge part of that market. Without it, the price of corn/beans would tank even more than it already has.
Another poster on that other forum made some good points: The 'problems' people experience with ethanol are usually other problems that the ethanol brings to light. Folks leave their lawnmower out all winter or store their tractors with the tank only 1/4 full. Condensation/moisture gets in, the gas sits on top of the moisture (gas being less dense than water), it sucks through a slug of water when they go to crank it next year and won't start. And they blame the ethanol content for 'separating' rather than their own storage practices which allowed water to enter. Ethanol is also pretty good at cleaning tanks/fuel systems, so if your tank and lines have a lot of crud built up in them, it can clean it off and the crud will then plug up lines and carbs. But it's no reason not to use ethanol. Once your tank and system are clean, the ethanol fuels will do a better job of keeping them clean.
Edited by DanielW - 05 Nov 2025 at 7:26am
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 5:40am
Been burning E15 since it came out.  E10 before that.  No additives, supplements, anything.  Zero fuel related issues.
AaronSEIA
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 6:03am
Short story; I've had bad luck with ethanol.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 6:07am
I, personally, haven't experienced the "gas going bad" problem that a lot of people talk about.
None of my tractors do any work. They are all toys and sit around, sometimes for months at a time. This week, I started three tractors for the first time this year, to move them so I could rearrange some of our (oversize) Halloween decorations that we took down.
Like some other posters, I started out using only ethanol-free gas. I now buy "regular" unleaded (10% ethanol) and haven't experienced any fuel related problems.
I do occasionally use Seafoam in tractors that don't get started very often, but it's more for my peace of mind, than because of any problems.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 7:22am
I run no ethanol premium and put some stabil in the tank for all my gas equipment an haven't had any issues.  Some of them don't get started very often, and zero issues.
19F150 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19F150 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 9:41am
I put lead additive in the gas
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 9:53am
I run E10 with Sta Bil 360.
Thanks to an EPA order, ethanol free is not available locally.  Not at all, no where.
I could go several counties away, but I have had no fuel-related issues with my B running the fuel bowl dry every time I run it.  The big issues with ethanol are rubber and water.  Pretty much no rubber in a B fuel system.  I have not had any issues with water.
1951 B
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 12:45pm
I like Steveill just kept on using pump gas when my socialist state made that all you could get. Things where fine until they were not. Had 3 chainsaws go bad, always being liberal with the amount of oil in the mix. Have several old ones that would still run just newer more powerful for the weight saws as this old man cannot lug the old heavy ones anymore.
So I advice a good amount of stabilizer in anything that sits much. I do drain some bigger engines. I have an old hay baler with Wis V 4 on it, parked because of the cost of bale wire. Well I only had 4 or 5 acres one year not worth renting a baler or getting someone. So a drag the old one out. Finaly with a new fuel pump it ran again. Two years later the same thing and the fuel pump was bad again. This is all fuel drained. I got brave took fuel pump apart, used a piece of innertube that was around as a diaphragm, and it WORKED. After another years rest it ran a second time with the make shift diaphragm. So some days luck is way better than doing things the right way.
But I will never say anything good about new made worse gas being ok.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 12:52pm
I run Sta-bil in all my ractor and garden tractor year around and they start up without any problems
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 2:08pm
In my state/neighborhood, 10% ethanol has been available since just before 1980. So, I've been using it exclusively in everything (except my push mower) for 45 years. Not one pennies worth of trouble with any Ford, Chrysler, Chevy or Allis-Chalmers in 45 years.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 6:35pm
first non ethanlol  and e 10 dont get along use one or the other  ,  second  octaine and compression go hand in hand   low compression low octaine  that will make the most power   the higher the compression  the higher the octain so  it does not detionate   7 or 8 to one compression  85 or 88 is plenty   i use  e10 85 in about everything execpt my snowmobiles get 91 non ethonal   pulling tractor gets 110
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 10:01pm
In these parts, some Walmarts, Allsup’s, and Cefco gas stations have 87 octane non-ethanol gasoline. During my the hottest, dog days of summer, when highs are expected to 100+ degrees, I will fill whatever car am using with non-ethanol. Always have a 5 gallon of non-ethanol for lawn mowers, chain saw, and for cleaning paint brush when using oil-based paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 34 minutes ago at 8:50pm
In discussions  about ethanol in gasoline it usually the folks from corn growing areas that don't have any problems running ethanol but almost all from other areas have problems
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 16 minutes ago at 9:08pm
All my air cooled engines will run hot if I run the 10% ethanol. Haven’t really tried it in the liquid cooled yet.
I had to run 10% ethanol in my 14 hp Kohler (my main mower) once and it lacked power and started to over heat. But it has been bored out and the head has been shaved…
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 33 minutes ago at 4:51am
Gary, I'm from the heart of corn country and grow some too. No fan of ethanol!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 7 minutes ago at 7:17am
hmm….
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 42 minutes ago at 8:42am
A while back, I bought a Terra-Tiger. Somewhere along the way, the engine had been changed to a (Chinese) Duromax 4 stroke engine.
When I went to look at it, the guy said it had set for several years and hadn't been started. I did pull it over to make sure the engine turned over and had compression. My intentions were to buy a new Chinese engine to put in it.
When I went to pick it up, the guy I bought it from told me he had put an old battery in it and got it started. It ran with the choke on but had very little power and didn't run very well. I asked him if he had drained the old gas. He said that he hadn't but got it started on the old gas.
I was able to get it on the trailer under its own power but barely made it up the ramp.
I brought it home and put some Seafoam in the gas. I had to run it with the choke out for quite a while, but eventually it did smooth out and actually runs pretty well.
I am betting this gas was several years old. I have no idea if it had ethanol in it.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 55 minutes ago at 9:29am
https://youtu.be/OHXYWxMkhog
  Only one fuel stabilizer works to keep ethanol from destroying aluminum, pot metal carbs.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 55 minutes ago at 10:29am
I run 10% ethanol gas in most everything but do add Stabil if it is going to sit for a long period or over winter.
Otherwise... I run ethanol free for my fuel mix for the Stihl chainsaw and I use ethanol free for my snowblower.
