What engine do I have? |
CTuckerNWIL
Topic: What engine do I have?Posted: 06 Feb 2010 at 12:27pm |
Sounds like a Leroi engine I saw in a drag line once. It might have Leroi stamped on the rear flange.
MikeB (SD)
Joined: 13 Sep 2009 Location: NE South Dakota Points: 80 |
Posted: 06 Feb 2010 at 12:22pm |
Check for the block casting number in raised letters below the magneto on the right
hand side of the block. It should say U3019-31 or AM3825-7 or something like that.
FRANKO
Posted: 06 Feb 2010 at 12:10pm |
I purchased a power unit advertized as a W25. That should have a WC block. This block is not WC. The unit has the 45 degree exhaust manifold, small carburetor, and older magneto correct for an early WC but the engine has a 4 inch high head with relieved spark plug holes making the plugs more accessable. The block does not have the mounting for the by-pass oil filter, has a pad for a fuel pump, no valve access cover on the magneto side, and a rather large buldge from the camshaft down toward the pan. It also has a boss in the casting, not machined out, that looks like it is for a distributor. It has a 4 bolt pattern above right that looks like the spot for mounting the coil on a D17 motor. I cannot read the serial number but it looks like the last digit may be a G. Can anyone identify this engine? Thank you.
Frank O.
