What does this serial # tell me?
donkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donkey Quote  Post ReplyReply Direct Link To This Post Topic: What does this serial # tell me?
    Posted: 04 Mar 2012 at 2:04pm
Hello All,
I went out and got the serial number off the D17 today.
d17-12651-M
does this make sense?  I was afraid to scrub to much more
for fear of losing any additional letters or numbers.
Thanks Jeff
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 2:12pm
1958?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 3:17pm
OK what's the M for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 7:49pm
I shouldn't have posted so fast. Is that an engine # or a tractor #? I really don't know anything about the new stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 7:50pm
I found it. S is low octane and M is gasoline, it's an engine # so I don't know what year it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote donkey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:15am
Where would I find tractor number?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:17am
Stamped on the left side flange of the bell housing.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 9:07am
I'm guessing the tractor number will be somewhere around D-17 18000 making it an early '59 Series I tractor. It will probably have the early style oil filter as used on the WDs and WD-45s. The color should be Persian Orange #1 and the rear wheel centers are probably orange rather than cream.
I used the difference between your engine number D-17 12651 and my engine number
17-29111 (16460 units) and subtracted that number from my tractor number D-17 34633 to come up with an estimated tractor number of D-17 18173.
There is not a direct correlation because there were engines built for combines and stationary units that were included in the same series of engine serial numbers.
I hope you post your tractor number when you locate it just to see how close I came.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 2:04pm
As already stated, that number is the engine serial number found on the left rear side of the engine block somewhat behind the carb.  M-code is a 7.25:1 compression ratio gas engine.  If the code was "Z" it would be 8:1 compression...don't have my Swinford book but I think "V" code was the 8:25:1 compression gas engine such as found in the 175.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote donkey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 7:02pm
Well I finally got over my Pneumonia and went out and found my serial number!
D17 14785
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 7:10pm
1958
Post Options Post Options   Thanks (0) Thanks(0)   Quote donkey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 7:26pm
Thank you Lonnie
