what did they do with this front axle
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Topic: what did they do with this front axle
    Posted: 16 Feb 2016 at 8:02pm
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2016 at 8:11pm
  not a factory set up
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2016 at 8:29pm
Some idiot totally trashed the tractor and the blade.....
ALLIS EXPRESS!
This year:
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2016 at 8:58pm
It's factory it's just not attacked to the tractor. They took it loose and laid it forward. You can see it there on the ground out front. Front of tractor is sitting on blocks.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2016 at 9:09pm
looks narrowed.
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2016 at 10:30pm
http://images.craigslist.org/00606_4veMsGHyd1W_600x450.jpg
http://images.craigslist.org/00d0d_jpSoqHlZ8rw_600x450.jpg
http://images.craigslist.org/01212_1qxA338EJx0_600x450.jpg
http://images.craigslist.org/00808_iH746tyLuaT_600x450.jpg
I'm sure it  "ran when parked" at least some time in the last 20 years or so. Still it could be worth something. The blade needs put back together if it is all there and so does the front end.
Edited by CTuckerNWIL - 16 Feb 2016 at 10:31pm
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2016 at 10:34pm
was a hard roll over!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2016 at 11:01pm
 Kinda looks that way with the left side of the rad shroud buckled, the right side caved in and the left rear wheel gots some camber to it Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2016 at 11:12pm
and the bent up steering wheel
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 6:18am
Ran when parked!! LOL!
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 6:45am
Ran when parked upside down....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 7:02am
well...ya don't hafta be wearing any clothes to work!
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 7:48am
But its valuable being that it's a 1935 WD, must be an experimental model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 9:07am
Aaahhh Yea!, this tractor has some serious issues! Rear wheels don't look aligned as mentioned. And front wheels look to have just been set there for the picture?? May have broke off the front end during roll over? Exhaust is not covered either:(
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 9:26am
It's sitting on some concrete blocks and chunks of timber to make it look as if the front axle is attached. Looks like a hard roll over to me!  Might be a good price for a parts tractor if the blade is included.
T.J.-N.J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T.J.-N.J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 4:09pm
Tires hold air till you turn your back, that looks like a treat to load up too. T.J.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 4:31pm
Just make sure you warns the public before you goes to do any work
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote T.J.-N.J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 8:36pm
Personally I think it went off the side of a trailer.
Dswall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2016 at 10:34pm
It Had a bad day!!
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2016 at 6:42am
Looking at the 3rd pic, front axle looks like it was tore off. Missing the pin on the back of the wishbone, and the wishbone looks bent.
