What did i do wrong and how can i fix it
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: What did i do wrong and how can i fix it
    Posted: 02 Jul 2025 at 8:07pm
Took the head off one of the wd 45 for repair( intake valves were not seating properly) finished putting back together and now i can't get it to start. I have a good flow of gas at the carburetor, a nice blue spark from all plugs. I double checked the timing( it didn't change but how could it) and the spark plug were in the correct order, 1243. What am i missing. I reset tappets at 016
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 8:27pm
Try pulling plugs, put a little gas in each cylinder with a dropper, reinstall plugs see if it fires then. I have a WD that needs that if I don't run it once every week or two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 10:02pm
Not to be a smart Allick, did you reset your valve clearance?  Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 11:15pm
1243 is the correct order... but WHICH ONE is #1 on the distributor ?? ... clockwise or counter clockwise ?
Edited by steve(ill) - 02 Jul 2025 at 11:17pm
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 6:17am
Are the spark plugs wet after trying to start the tractor, maybe carburetor problem.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 6:34am
I did put a little gas in the cylinders and often i get a "pop" when i let off the starter. And you are not being a smart alleck about resetting the valves, i did, 016
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 6:35am
And clockwise on the spark plugs wires
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 6:52am
I bought a WD awhile back  very hard to start and ran worse and worse as it warmed up.Per past experience took off the valve cover, about all the valves were adjusted too tight.Loosened up the valve starts and runs great now.I've run across this with a lot of old tractors over the years
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 8:10am
It takes 3 things for it to run:  COMPRESSION.......fuel/air mixture at a proper ratio..........good spark at the correct time.  Being as how you just did valve work, in 5 minutes or less I could run a cranking compression test and VERIFY that compression ain't (or is) the problem. Have the throttle wide open and a battery charger on the battery to do this.    How about a leaking intake manifold gasket(s) ??? You worked on valves and had the manifold off. If the carb wasn't touched, that shouldn't be the problem. Timing shouldn't be an issue either if you never touched the distributer.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 7:58pm
130 all four cylinders. That has become my mantra since you answered one of my texts 10 years ago. Did that before i put the hood back on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 8:03pm
if you have good compression and you have good fuel flow and spark.... then spark timing could be the problem.... Im still wondering if a couple plug wires are switched, or all rotated one hole off on the distributor cap.... not being mean.. its a common problelm.
Edited by steve(ill) - 03 Jul 2025 at 8:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 8:09pm
Compression will be fine even is there is an intake manifold gasket leaking.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 10:44pm
you say you get a pop when you let off the starter are you getting enought voltage to the coil when cranking  is their good spark when cranking
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2025 at 5:27am
That was my thoughts too, sounds to be a spark/ign switch maybe kind of issue.
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2025 at 12:14pm
Sounds to me like it could be just a simple connection problem. I don't know if its been raining up there like it has been down here, but man between the humidity and the wet weather, that would cause a bad connection issue somewhere in the ignition circuit or at the key switch. If you just pulled the head off, you never touched the Distributor some timing wouldn't be an issue as the Doc mentioned. If a spark plug wire or two were on wrong, it would probably be backfiring through the exhaust or Carb. You need spark for that. Not spark, no boom or pop....  HTH
Steve@B&B
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2025 at 9:53pm
Itd been raining and raining and raining. And my garage has a gravel floor
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 9:31am
May or may not be similar to your issue, I had a D17 do the same, crank but not start/pop until key was released to the run position then ran great.  I removed some damaged wiring and discovered afterwards there is a separate wire supplying power to the coil from the start circuit.  Fixed that and started and ran like it should.
IB (restoring), MF GC1705, MF 2705E
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2025 at 1:03pm
That short statement also caught my attention. To test that theory, use a separate battery with jumper cables to power JUST the distributor and coil. Do not turn the ignition switch on. Crank the engine over with the tractor battery and see if it starts. Also some engines need a LOT of choke when the head is taken off and put back on.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2025 at 5:20pm
A few years back I had the same problem with my 45.  What I found was that the ignition switch was bad.  Just happened all of a sudden.
When cranking, it worked well and wouldn't start.  Would let out a 'pop' when letting off the key.  Swapped it with another running tractor and it popped right off.
Bought a new switch and installed and it's still working.
Don't know what the trouble was, the the switch turning too far?  Broken off point inside?  The solder let loose?  I don't know as I didn't bother to take it apart.
Give it a try...
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 5:59am
Replaced plugs ,cap, rotor yesterday. Cleaned up all the contacts on the entire electrical system. No change . Going to pick up a voltage tester today. Its a six volt system. What kind of numbers should i be looking for and at what spots on the system should i check
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 6:26am
Takes 2 people.  One in the seat to yank on the starter pull rod. Remove the coil wire (center) from the distributer cap. Hold the end of the wire 1/4" from the cylinder head or block casting. Crank the engine. There should be a healthy blue spark. This is the first test with zero tooling.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2025 at 7:44pm
Got a blue spark from the coil on the tractor but went through my stuff and found a six volt coil thst was two inches taller. Figure bigger is better and true to form, the blue spark is much more impressive. Still did not start but more sounds like it wants to
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 5:22am
Are you sure the plug wires were replaced in the correct orientation on the distributer cap? With #1 cylinder on TDC at the end of the compression stroke, the rotor should be pointed at the #1 plug wire. Going clockwise should be 1-2-4-3.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 6:09am
Yeah, checked that many,many times
jdeere562 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdeere562 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 9:10am
Had a guy bring me a WD many years ago. Was running fine until he converted it to 12 volts. It cranked very fast and would not start until you let off the starter, and the engine slowed down. He had done nothing to the distributor or ignition system.
Ended up the timing was too far advanced from cranking so fast. Had to put slightly heavier advance springs in the distributor. Highly doubtful that would be your problem,
beings you only had the cylinder head off.
Just an example of a head scratcher that one can hit at times. They can make you pull out your hair and then be something simple.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 9:38am
Did you leave a rag in the air intake for keeping debris out while working on it? I’m half joking half serious. You have compression, spark, fuel (?) air? Pretty much leaves timing, blocked / leaking intake, blocked exhaust? Crazy.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 10:25am
Instead of cranking over with the starter, try ‘pull starting’ the tractor.
DB74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DB74 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 1:05pm
Curious about the possibility of a leaking intake??
What is the best way to test/check for this condition?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 1:37pm
Intake/exhaust manifold should be installed by snugging the very front and very rear stud nuts first. This will "square" the manifold to the cylinder head. Then, tighten the other nuts by alternating top to bottom and bottom to top. Do this in several steps to keep the manifold flat against the head.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 1:52pm
Old gas, gas with ethanol that absorbs moisture ??
This page was generated in 0.438 seconds.
