what carb is bigger
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: what carb is bigger
    Posted: 07 Jun 2013 at 2:03pm
than the stock carb on a wd, maybe one off a wd 45 or? if it has to have an adapter or something made that is no problem
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2013 at 8:25pm
45 is bigger.  I'm sure a D17 carb would fit as the aftermarket manifolds are generic fit between WD, WD45, and D 17.  I'm sure someone who pulls can chime in with a better plan or some internal magic that'll help as well.
AaronSEIA
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2013 at 10:35pm
Aaron is correct. We have a WC with the one size fits everything replacement manifold, from WC-Early D17 that has a MS carb off a WD45 and another WC with an original WD45 manifold Gleaner "E" carburator that's similar to the WD45 carb on the other tractor. One tractor is a 217 cid engine with the stock 4" crank and the other is 240 cid with a WD45 4.5" crank and both tractors run really great. Kip
