What brand do you suggest?
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Topic: What brand do you suggest?
    Posted: 08 Oct 2022 at 6:26pm
I bought an expensive, brand new Stihl trimmer so I could use it around the farm. It's spent most of its time on the tailgate of my pickup being worked on.I've had it back at the dealer several times. It's at the dealer now. The string won't feed out of the head. Original head. Haven't used it enough to use up the string in the original head. Every time the string breaks off I have to manually open up the head & feed some more out. The problem right now is that it won't run. It sputters for a bit then dies. I'm using Stihl gas. The problem could be a trimmer that's a lemon, or a dealer that's a lemon. Stihl hasn't helped, either. I think I'll try a different dealer & if the trimmer still won't work I'll have to give up on it. What other brands of trimmers are reliable? I need one for farm use like trimming around buildings, fence posts, etc. Are the electric trimmers any good?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 6:32pm
I gave up on trimmers 15 years ago..... My new trimmer is called ROUNDUP... Only have to "trim" once every couple months. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 7:11pm
I have a almost fifteen year old Stihl 4Mix string trimmer, best trimmer I have ever had. Can be a SOB to start first of a season but thereafter always good.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 7:17pm
I've had good luck with my Echo, or I should say the boy had, think I've run it once a year since he graduated and moved away three years ago.  But still starts and runs every time.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 7:45pm
I like my Stihl trimmer and leaf blower. Never had a problem with either. Sounds like you got a bad one which sucks.  If you go to a different brand avoid the Menards junk.
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 7:59pm
Can’t answer the engine issue but might want to make sure the string is wrap the right direction.
Nephews have a lawn care business w 7 or 8 crews going out daily. Stihl is all they use.
D17 Series 1
Allis B- 1939
Allis B- 1945
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 8:28pm
We have a Huskvarna that has been trouble free for over 8 years.
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 10:30pm
Echos are dependable and ours trouble free
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 11:17pm
I also like my Echo
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 5:46am
I prefer my Troy Built 4 Cycle stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 6:47am
More Made in China, KRAP !!
I was 'gifted' TWO Stihl trimmers, lightly used, PITA to get going and stay going.After wasting a day ,I 'regifted' them to someone with more patience than me.
I really like my Ryobi battery powered trimmer. Manual string feed. battery lasts longer than me, really need the shoulder strap.
Have no idea why your NEW Stihl, running Stihl fuel won't run,and equally sad dealer can't fix it. Maybe (?) he'll take it back on an battery version ?? If not ask Stihl USA directly.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 2:49pm
When the string gets old it becomes brittle, dry and breaks off in the head.
Solution is to buy new string or soak the string head in a bucket of water.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 4:37pm
X 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 5:41pm
vinegar/salt/soap = poor man's Roundup
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 5:58pm
Milwaukee M18 string trimmer, I have the 12AH batteries, and I'm usually out of power before the battery is. My mom also has one, she has two 6AH batteries, a little lighter for her, she really likes it, and she doesn't like anything new/different.
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 7:09pm
I tried the salt/ vinegar/ soap mix. Generic weed killer from RK was cheaper and the results about the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 2:44am
the old lady.....ooooops....I mean the loving wife has a battery B@D trimmer, I won't let her use my Echo. she likes her own trimmer, and I feel safer knowing she is using that one!
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 1:39pm
I consider myself as a fairly good small engine mechanic but in the spring three years ago when I spent over two hours trying to get my string trimmer to run my wife said that as a early birthday gift she would pay for a new string trimmer. I went up to Home Depot to look for a new one and saw that they had a Toro battery powered trimmer on sale for less than gas trimmers. 60v battery and dual strings. What a beast. Out performs any gas trimmer that I have ever used. You can go all day on a charge. No more mixing gas, little noise, no smell.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 2:01pm
 I have a Troy-bilt 4 cycle that you can use a battery powered drill to start the I have had for 6 or 8 years and it has worked great only use it about 3 times a years and use stabilt in the gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 5:30pm
I stil use the stihl Kombi-system, But I added a ryobi 18 volt trimmer, I carry it on the foot deck of the Altoz.  Nothing beats it for portability, its about 4' long, short enough to carry on the mower, under my legs, yet long enough to reach out (from the operator's position) and trim around those obstacles that are several hundred feet from anything else.  Sure saves steps, on the weed-eater circuit!
This guy is all exuberant about it, But Ryobi prolly comped him the weedeater for the review...  Mine I got with 10 other ryobi tools, offa craigs list, for $195...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 6:26pm
I would check it for a mud dabbers nest if it doesn't run or run well. String could be old. Once you load the string, you should manually be able to tap it and pull string out evenly. If not, something is binding. As for the brand, Husqvarna all the way!  JMHO, Tracy
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 7:14am
You're wasting your breath.  I calculated his recipe once too and also found it more expensive than roundup.  But that doesn't matter.  You have to remember, Canada sucks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 7:52pm
Daang, man. A little tough on Canada aren't we?Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 10:11pm
I think it's like here and most places around the world.....it's not the people (the country),it's the governments that suck.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 11:13pm
The problem with ANY string trimmer, is that the string is always more sacrificial than we desire.
I've replaced my string heads with swinging flail heads... one of my Stihl trimmers has plastic blades, the other are steel, and other than the plastic blades wearing out faster, and not being as effective on saplings, they're a whole lot better than string.  The steel flail on my FS80-something will chew a 2" Mulberry sapling off in 8 seconds.
The one certain thing you'll run into with ANY 2-stroke trimmer, is that the spark arrestor screen on the exhaust will foul, and cause the engine to become constricted to the point where it just won't run.  One of the primary causes of screen fouling, is just simple idling-time... running the engine hard keeps the screen hot, hence, it generates LESS soot deposits, and it's hot enough such that it burns off those that DO accumulate... so running them gently is actually 'hard' on 'em.  Many guys remove the screens and open up the muffler exit baffles to improve breathing, at the expense of a little more noise, and this certainly helps mitigate carbon fouling.  Just so happens that my Echo CS3000 top-handle has a carbon-fouled screen that will be coming out when I get it on the workbench for a goin' through... it's about two years' overdue...
Fuel pickup filters, hoses, primer bulbs, and carb diaphragms are a consumable part- replace them regularly.  Once one of the hoses develops a weak spot, they'll crack, and allow air to be sucked up the line, leaning out the mixture and stalling the engine.  Air filters can plug up fast if the outdoor circumstances are right, and when they do, it's oftentimes not visually obvious they've become restrictive.  Oil settles in fuel, causing the mix going into the engine to be substantially different from what one expected (this is especially true of any ethanol blends, as they're aggressively hygroscopic).
As for recommendations, Stihl, Husky, Echo, Shindaiwa, Dolmar, Makita/Hitachi... They're the most likely to yield 'professional-grade' stuff, but there are more 'homeowner' grade in their lineup, at least they're better than 'big box' brands.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2022 at 8:41pm
My Generic Roundup never fails to start, dont use any gas, and never needs a carb adjustment !!   Wink  Clap  ..........about $50. a gallon now... Use to be $25... 2 years ago !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2022 at 6:31am
Price is for concentrate though, right?
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2022 at 7:27am
I am with the climate people and have an electric trimmer, always starts
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2022 at 8:21am
I bought an 80 volt electric from the local lawn mower shop.   You could cut your first cutting of hay with this unit. It will run about 2 hours before I have to switch batteries.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2022 at 8:51am
YEs Tbone... moany FARM stores sell a gallon of GENERIC 41% Glyo - for about $50... You mix about 4 oz to a gallon... 128 oz  in a gallon..... so you get 30 some gallons of mix... IN a 3 gallon weed sprayer thats 10 fills.... If your doing a 1/2 mile long stretch somewhere, you need a few refills... If your doing the driveway and around the yard, you can get a couple YEARS out of a gallon,
$50, FREE delivery... Home Depot
Edited by steve(ill) - 13 Oct 2022 at 8:57am
