What bolt grade to mount loader? |
JaredC(WI) ![]() Silver Level ![]() Joined: 10 Apr 2019 Location: Birnamwood WI Points: 106 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Aug 2019 at 7:37am |
Thanks, all!
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88219 |
Grade 8 bolts are normally for Head Bolts and Rod bolt type applications. Nothing wrong with using them for the loader, but WAY overkill..... its your money.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
grade 8!!!!!!!!!!!
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3093 |
I've owned and seen a lot of loaders have never seen a grade 8 bolt snap off if 5 was stronger then there'd be no need for grade 8.And if sudden impact broke grade 8 so easily they'd be used for shear pins(LOL)
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54284 |
Grade 5 and never-seize...
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
I agree, 8 are too brittle for that application. Go with 5. Fortunatly I had the original bolts for mine, when I mounted it.
Rhoadesy_65 ![]() Bronze Level ![]() ![]() Joined: 28 Jul 2019 Location: Versailles, OH Points: 164 |
grade 5 will take shock loads better than grade 8. Grade 8 will snap not bend. Usually
hear use grade 5 for shock loads and grade 8 for constant loads.
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
I use the 8's, then you know they are good for anything you could throw at a 2 or 5 grade on a loader mount.
You'll never go wrong with grade 8 bolts with something like that,plus they don't rust nearly as bad as lower grades.I rarely buy anything but grade 8.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
Grade 5 works great the original square heads were grade 2
grade 5 should be overkill for the loader.... That's a good idea.. much better than the grade 2 basic stuff.
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2074 |
Grade 5 or 8 would work well.
Thanks & God Bless
Dennis |
Finally getting closer to actually mounting the old Henderson loader I got this spring on my CA. Hoses have been replaced, cylinders rebuilt and just waiting for the call saying fluid is back in my rear tires.
What grade bolts should I be using to mount the loader frame to the tractor? Thanks! Jared |
