What are these hard points on fuel tank for?
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: What are these hard points on fuel tank for?
    Posted: 12 Nov 2018 at 8:30am
Hello Friends.
Posting 3 pics of my HD16 fuel tank facing the inside of tractor. As I sand and get ready for prime, I have been curious of what the hard points or brackets are for on my fuel tank. They appear to be factory installed and was wondering what they were used for or what attachment was used on it. One of them which I don't show is all the way to the left side if your sitting on in the seat. I am going to use that for a rear flood light and it works perfect for that. Any ideas what these other brackets are for. The one in the middle has matching ends to each side of the fuel tank, almost like something could or did slide into it from above.
Just a curiosity so looking forward to any of your ideas.
My thanks.
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 8:42am
Securing the fuel cap from theft ?
Seat brackets if on inside operators station .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 8:45am
Wow,, guess I better check my settings. Here they are again.
Hope this helps. Wont know till I post reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 8:46am
New phone. will have to figure this one out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 9:22am
Good idea on the fuel cap chain, that could make sense. The bracket in the middle and above the seat and battery box brackets is the one I sent oilfield like to figure. It’s above the seat brackets which stick out and in the middle and each side. Sorry the pic is too big but you can move right and left and up and see it clearly.
Thank you Coke.
Morten.have View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 2:14pm
Hey jerry. It’s all for seats backs or backrest if you whant. the 4 vertical angel pieces they steer the seat movement sideways. The 4 (green) horizontal it’s for the seat backs bolt on. The 2 piece horizontal is for the backrest slider hook. I have made a drawing for you and pic of the original seat. I have the 2 seats assembly left because I added 2 air suspend seats , and you can have them both if you want to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 2:18pm
Here is a pic when it’s was mounted but only the driver side the passenger side I already had removed .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 2:40pm
Morten you nailed it. Thanks to both you and Coke. Thank you for the offer on the seat or seats my friend, however my charming wife made me new seat bottoms and Backs and the arm rest for the right side driver seat. Some before and after.
Hope you can tel the before and after shots. ;)
Thank you gentlemen, I have a nice chrome chain for that fuel cap Coke. Should add a little bling.
This page was generated in 0.355 seconds.
