WHAT ARE DUAL'S WORTH? |
SIMPLICITY
Joined: 19 Sep 2009 Location: ERATH LOUISIANA Points: 517 |
Topic: WHAT ARE DUAL'S WORTH?Posted: 19 Oct 2010 at 8:57pm |
HELLO
I AM LOOKING AT A SET OF MEXICAN HAT DUAL HUBS AND WEDGES TO PUT ON A 7060 ANY IDEA WHAT THEY ARE WORTH? WILL NEED PAINT HAS NO RIMS |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4574 |
Posted: 20 Oct 2010 at 5:22am |
I bought a pair of Mexician Hat duals with rims at an auction last month for $150. He was asking $400 for them a year before the auction. I'm told that both prices were a good deal. I'm planning to use the duals on my 220.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 20 Oct 2010 at 5:56am |
I see them go from $150 to $250 at auctions pretty regular and sometimes less.
Wink I am a Russian Bot |
Dale Hardtke
Joined: 12 Sep 2009 Location: Watertown WI Points: 171 |
Posted: 20 Oct 2010 at 9:12am |
I think we have some confusion about the term mexican hat dual hubs. According to Swinford, Mex. Hats are the 350# casting that axle mounts with six bolt wedges and provides an outside Dia.to hold 38" double bevel rims with 16 clamps, or power adjust rims with 8 clamps. NOT the lighter 120# castings that bolt to the six bolt 16" Dia. bolt pattern on the inner wheel casting and provide a nine hole hub to mount a 34" die formed outter wheel rim. Mex. Hat's were first made to be used on 220/210 tractors and later carried over into the 7000 series. I would think that they would work on any AC tractor W/six bolt wheel wedges and enough axle length. I'm thinking there is some confusion based on the prices given for the Mex. Hat dual castings.
Lonn
Posted: 20 Oct 2010 at 9:57am |
Yep, I was confused. So I have no idea but I wish I had a set of "mexican hat" duals.
Calvin Schmidt
Posted: 20 Oct 2010 at 10:02am |
The duals that I bought were the heavy 38" with the 350# cast centers and double wedges that Dale mentioned. I have the smaller 34" set with the 9 both pattern for pressed steel rim duals on my D-21. What is the correct terminalogy or name for each?
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Posted: 20 Oct 2010 at 10:47am |
here is a picture but kinda hard to see. So these ar NOT mexican hats?
Dual mounts And these would be Mexican Hats" Daul mounts Edited by Matt MN - 20 Oct 2010 at 10:52am |
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1219 |
Posted: 20 Oct 2010 at 12:18pm |
Neither of those are mexican hat duals, the bottom looks like a long axle tractor with 2 standard cast centers. Mexican hat duals are like the standard cast centers, but just imagine the center of them being "punched" so that it is offset. I tried to find a picture on google, but couldn't find any in my quick search.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Dale Hardtke
Posted: 20 Oct 2010 at 9:19pm |
Hurst: You got it correct.
