What Am I Missing? |
tamuron
Topic: What Am I Missing?Posted: 25 Aug 2024 at 4:28pm |
I have a Allis CA that I trying to fire up. Head Professionally re-worked, all new everything. Great Compression on all 4, Hot Fire and clean gas..6 volt system.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 25 Aug 2024 at 6:28pm |
Distributer or Magneto ? Edited by Gary - 25 Aug 2024 at 8:50pm |
tamuron
Posted: 26 Aug 2024 at 1:25pm |
Distributor |
tamuron
Posted: 26 Aug 2024 at 1:28pm |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1125 |
Posted: 26 Aug 2024 at 9:22pm |
Timing? Use a timing light to check
Joined: 11 Sep 2009 Location: illinois Points: 90825 |
Posted: 26 Aug 2024 at 9:43pm |
if you have gas and you have spark, then the timing is off... Rotate the motor to TDC on the front cylinder... Look at the distributo rotor and see that it is pointing at #1 lug....
Also the wires on the cap are 1-2-4-3 ... in a clockwise direction. The FIRE mark on the crank is the ADVANCE position you will get when the motor is RUNNING... To START it should fire near Top Dead Center.
Edited by steve(ill) - 26 Aug 2024 at 9:46pm |
im4racin
Posted: 26 Aug 2024 at 9:54pm |
Set timing to the fire mark at wide open throttle. Not at idle
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 26 Aug 2024 at 10:11pm |
if the head was off is the over head (valve lash)done on the right stroke
