What adapter is this? |
Amac67
Topic: What adapter is this?Posted: 25 Feb 2024 at 9:34pm |
I picked this up at an auction with some other stuff awhile back. Best I can tell, it’s a 3 point adapter. Does anyone have any specific info on what it is or what it fits? I’m new to the hobby,any and all info is great.
Mikez
Posted: 25 Feb 2024 at 10:21pm |
It’s not a 3pt adapter. Pieces of a snap coupler hitch. I don’t think that’s how the lift links would be attached. Maybe pieces of a cultivator
Joined: 11 Sep 2009 Location: illinois Points: 88649 |
Posted: 25 Feb 2024 at 10:35pm |
Ii think if you had a 3 point implement ( plow / blade) and you bolted this to it.... You might be able to mount it to the ALLIS bail hitch system ?? ............ it appears the bracket that mounted to the TOP LINK of the 3 points is cut off ?
![]() Edited by steve(ill) - 25 Feb 2024 at 10:45pm |
Posted: 25 Feb 2024 at 10:48pm |
maybe similar to this ?? ... but the above is a FIXED attachment for 1 impllement ?... not to be moved between implements.
![]() Edited by steve(ill) - 25 Feb 2024 at 10:49pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54463 |
Posted: 26 Feb 2024 at 4:04am |
It appears to be the bottom link to a plow or bush hog, that has had some booger weld surgery...
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 26 Feb 2024 at 2:22pm |
My rear mnt cultivator has similar hitch...the ball on the left is sandwiched between two metal bars which does the lifting allowing it to sway. A ball on each lift rod. This is a modified something.
Amac67
Posted: 26 Feb 2024 at 7:23pm |
That is closest thing I’ve seen to what I’ve got here. She’s definitely been heavily modified to suit someone’s specific needs. Missing some pieces too for sure…It’s hard to see but ahead of the top links on both arms are drilled holes (appear to be factory) where that top adjustment is at. Great picture of that attachment, thanks.
Edit, this was supposed to be a reply to Steve but I’m learning this forum business..bare with me Edited by Amac67 - 26 Feb 2024 at 7:24pm |
Amac67
Posted: 26 Feb 2024 at 7:25pm |
I’d be curious to see a picture of your setup if it wasn’t much trouble. |
