What 6 bolt hubs? |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4200 |
Topic: What 6 bolt hubs?Posted: 02 Jan 2017 at 11:49am |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3955 |
Posted: 02 Jan 2017 at 12:38pm |
I believe 6 bolt hubs from an early WC will fit on those spindles.
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Posted: 02 Jan 2017 at 2:04pm |
I think so too. I took wheel bearings out of a WD and put them in the 6 bolt hubs on my WC.
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
dawntreader74
Posted: 02 Jan 2017 at 6:51pm |
thank' the oliver 77 6 bolt hub will also work.
IBWD MIke
Posted: 02 Jan 2017 at 7:23pm |
Thanks for the ideas, any others?
dawntreader74
Posted: 02 Jan 2017 at 7:32pm |
have them tires mounted on your wd rims' would be less work' much cheeper.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8755 |
Posted: 02 Jan 2017 at 10:40pm |
I'm thinkin them rims are a bit wider than skinny WD's. I put some GM(Buick?)rims(15x6 I think) on my 45.Had to skin a little outa the center but not much.Think they are the same size as his...7.5L's Edited by SteveM C/IL - 02 Jan 2017 at 10:46pm |
Bill Deppe/AC Salvag
Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
Posted: 02 Jan 2017 at 11:03pm |
Have a set of WC 6 bolt hubs on my reverse WD, fitted on without making any changes
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 03 Jan 2017 at 6:21am |
I know GMC truck rims fit the CA rears. Had to flip them 'inside out' but it sure made moving it easier!
IBWD MIke
Posted: 03 Jan 2017 at 12:21pm |
They are 15" tires. I bought the rims from a coworker pretty reasonable, believe they came off a 4020. I painted them white because they may wind up on the 185 but would rather put them on the 45 if I can find the right hubs and put new 11L15s on the 185.
michaelwis
Posted: 03 Jan 2017 at 12:40pm |
We put 6 bolt hubs on our D15 many moons ago.
Got them from Tractor Supply in Madison |
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Gerald J.
Posted: 03 Jan 2017 at 7:00pm |
If you can find trade numbers for the bearings and exact dimensions on the spindles, its possible there might be a stock hub from Baum Hydraulics http://www.baumhydraulics.com or Shoup http://www.shoupparts.com
If you dig into the tapered roller bearings of the Baum catalog you will find that there are several cones and cups that have the same roller dimensions but sometimes a wide range of spindle and cup dimensions, so the critical dimension on the hub and spindles are more often the length between the places the bearings ride. Baum also sells seals, another variable. I know one of the stock hubs that both of those places carry fit my AC plow when I broke the hub. Gerald J. |
IBWD MIke
Posted: 04 Jan 2017 at 10:08am |
Thanks for the ideas guys, much appreciated.
