WF shifter adventure.
fleeter allis fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Topic: WF shifter adventure.
    Posted: 13 Jul 2020 at 9:57pm
Hello All. i have recently had some issues with the shifter on my WF that some may find moderately interesting. I bought a WF about a year ago with a known problem. It occasionally gets jammed in second gear. It is quite a pain to get the thing out of second gear, as you have to lift the shifter assembly out of the transmission and get everything back into neutral again. To get the shifter assembly out, you must remove the starter, and the control panel, and the battery box is really in the way, and it is easier if you take the hood and the tank off as well. A great design.
I recently tried to sort out the problem, once and for all. The whole thing seemed loose and a bit sloppy and the reverse interlock did not seem to work. I took the whole assembly apart on the bench and found that the grooves where the pivot pins fit into the pivot ball were pretty badly worn. I welded it up and ground it down so that everything fits a bit tighter. I also found that the reverse latch interlock was hanging up on the bottom of the shifter rod. When I checked the parts manual, it was not together correctly. This told me that it had been apart and messed with in the past. More on that in a minute.
I sorted that all out and put the whole thing back together again, and it promptly jammed in second gear again. When I took it apart again, I noticed that the first and second gear rail was pushed forward (into second gear) when the end of the shifter rod was still in the neutral position . I have heard of gear shifters jumping out of gear, but in my case, it seemed to be jumping into gear. I could not figure out how the rail could be moved without the shifter moving it.
I read all of the relevant areas in the service manual and I found a description of the little "interlock plugs" that provide the detent tension between the rails. The two interlock plugs must be .566" long (mine are .565") and the interlock pin between them is supposed to be .546". Mine was nowhere to be found.
I figure that whoever had this assembly apart in the past lost this small part and reassembled it without realizing that it was missing. I made a little piece with the correct dimensions and reassembled the whole thing. It will never be mistaken for a sports car, but it shifts much crisper and firmer than before.
Without the little interlock pin, I believe that on occasion, when shifting into reverse, if the reverse gear did not mesh cleanly, without the interlock, it would bump one of the main gears forward, jamming it into second gear when the shifter rod was actually in the neutral position. I tested the whole thing by shifting in and out of every gear 100 times and today, finally got the tractor started up and did some test driving and again, shifted in and out of gear several times.
So far, so good. I guess when you are dealing with old machines, you can not depend that everything is still like when it left the factory.
I'm a man...and I can change...if I have to... I guess.
'44 B, '46 WF, '49 G, 810GT, 916H, 620
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2020 at 11:35pm
good eye to catch the part that was missing
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 6:08am
Your story of fixing the shifter shows me you are a good mechanic.   My first time into one of those shifter tops when I slid one of the shift rails out a detent ball went wizzing past my face, lucky for me it didn't take my eye out, so I can see how someone could have lost one of those.   Good for you getting it fixed !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 7:01am
Nice job with your work and research on the WF shifter. Missing parts are important! We need some pictures too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 8:11am
Thanks for your comments. I am a rookie mechanic trying to learn as much as I can and making lots of mistakes in the process. I think it is important to have the correct manuals in front of you before you get into something that you can't get out of. Yes, the ball went flying the first time I took it apart in my case too and the spring hit me in the nose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fleeter allis fan Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 8:14am
Thanks. I should have taken some photos I guess, but sorry, I am not taking it apart again unless I have to.Wink
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 11:40am
Great job, fleeter!  I have 2 WF's.  1 unstyled, serial # 13, and the other styled.
This page was generated in 0.428 seconds.
