WF pinion bearing needed |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Topic: WF pinion bearing neededPosted: 29 Jun 2024 at 2:07pm |
I am looking for a pinion bearing for a WF. I assume it's the same as a WC, but I'm not sure about that. The bearing is a Bower RS 5305 W. I don't know the AC part number.
According to the Bower catalog, the ID is 1.2506" (31.765 mm), OD is 2.4419" (62.024 mm) and the width is 1.0620" (26.975 mm). I didn't ruin the old bearing taking it out, but it is seized (currently soaking it in Evaporust) and there are several pits in the rollers. Everywhere I look on the internet, it is out of stock. Anyone have any ideas?
Joined: 11 Sep 2009 Location: illinois Points: 90897 |
Posted: 29 Jun 2024 at 4:06pm |
Maybe ???........ this is from AMAZON.... dimensions match your bearing per the second post below ..
Edited by steve(ill) - 29 Jun 2024 at 4:12pm |
Posted: 29 Jun 2024 at 4:10pm |
Mikez
Posted: 29 Jun 2024 at 11:05pm |
Is it in this picture ![]() |
WF owner
Posted: 30 Jun 2024 at 6:32am |
It's hard to tell. I'm sure it's in the picture in the lower left. It's the only bearing inside the differential on the input shaft (in from the transmission). It is right behind the pinion gear. (Maybe #69, but it's hard to tell.
I think I ordered one from the internet. (Thanks Steve!!!). After you order, they tell you (in one business day) if the bearing is available. Another question. Are the gaskets available for the two "covers" on the front of the differential? (One should be on the front of the housing in the lower left picture and another on the housing in front of that housing.)
