Western fire smoke - poor tv signals?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: Western fire smoke - poor tv signals?
    Posted: 28 Jul 2021 at 8:20pm
Is there any correlation to our tv signal being poor because of our air being smoke filled from the western wildfires?
Olympic channel comes & goes. Seems worse at around 3pm & later after 8pm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2021 at 8:43pm
Im on DISH... No problems noted unless there is a heavy rain storm SWest of us.... Satellite is basically over  Texas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2021 at 8:48pm
Smoke/haze can affect satellite tv signal somewhat. A hard rainstorm will knock ours out completely. But I am not sure about at antenna (over the air) signal. I have the antenna set up at the farm and it goes out for no apparent reason but affects mostly the higher frequency channels. I suspect it may be interference from some other source.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2021 at 9:31pm
i think it has affected ours
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 10:41am
 Wink More likely danger rays put off by that Toy of Yours.LOLLOLLOL
We did not have trouble last year cover by smoke for 3 weeks. Had grandkids for most of a week in there, TV worked or they and grandma would of all been screaming.LOLLOLLOL
Computer is satellite feed here and it was a bit slow but did work.
Glad to be able the share the Fruits of having Fruits and Nuts running the west today.
Wink The biggest fire in Calyforny was started by lighting on July 4. Burned for 10 days and was less than a 100 acres. Part of the new let "Nature Do its Thing", school of management. But then it got to the has not burned in a 100 years area stuff, and off to the races.
Wink All the fire fighting agency's put out every spark for close to a 100 years in the forests of the west. Finally decided better to burn it on there time than as wildfires. Now the Nature Knows Best groups got together with the save the World from Mankind idots still cannot do semi controlled burns in wetter times of the year.  No end to the mistakes of the past in sight yet.CryCryCry
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 1:29pm
Shameless, mine too, I just blamed it on old age and I am not talk'n about the TV setLOLLOLLOL
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 8:51am
Weather forecast included "smoke" and I was wondering where it's from.  Pretty hazy here.  It hasn't affected my fiber optic signal Pinch.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 4:05pm
Smoke in the atmosphere WILL affect VHF and UHF (over-the-air TV, amongst many other things), and it IS affecting it.  It can both suppress, as well as enhance propogation.
With today's 'digital', either enhancement or suppression (which CAN be BOTH) can result in poor reception simply because some OTHER signal is being transmitted in same frequency.
Smoke can also accumulate on your antenna's elements and feedpoint connections, causing it t develop shorts, or additional capaciity, hence, serious losses in performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 4:49pm
We're finally getting some much needed rain here today, which should help clear some of this off.
