Were these the only 2
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Topic: Were these the only 2
    Posted: 08 Dec 2010 at 6:42am
While feeding cattle with my AC-200 yesterday,I was thinking how handy the trottle is located in the right hand console. I know the model 190 and xt's were the same,but did any other AC tractors have throttle on the right hand side? I'm not sure about the model 7000 tractor or other 7000 series tractors. Hey it's cold here in KY. and I guess i'm just bored.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 6:55am
I thought sombody said the late 8010 had one there.By the way it was 4 degrees here this morning now we are up to 7.
B212,716,two 314H's,WC,WD,D19,190XT
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 7:04am
On the 8000 series, originally the throttle was on the dash, but then they moved it to the console and the earlier ones could of been updated to the console throttle. So if you have an early 8000 series, and it's original, it'll be on the dash: if it's been updated,it'll be on the console. By the way, it's cold here in ND also, been dropping below zero at night. Darrel
Wade (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 8:00am
Not having the throttle on the console on an 8000 series would make it hard to use, even for long armed guy..
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 8:01am
I always thought is was dumb that Allis didn't put the throttle on the console on every Allis after the 190 came out. -4˚ here in Rochester.
Wink
I am a Russian Bot
Joe Graunke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Graunke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 8:41am
I heard rumors that the 6000 series were going to have power shift put in. But with the selling of AC off never came to be
Joe
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 10:46am
7000 series all were on the dash.
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:31am
Might still find a kit in a dealers stock for an 8000 series if you looked hard enough. It has been a while, but it seems the number was 70275889 or something like that.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 11:33am
the 7000 series was on the right side of the dash, the lever was long enough that it was easy to reach.  On the first 8000s it was on the right side of the dash too, but the lever was shorter to allow room to get out the right side door, very unhandy.  7000s didnt have a right side door.   The mod kit moved the throttle lever down on the console where it shouldve been in the first place.  I did a few of those and it was a PITA to install but sure worked nice when done.
LoggerLee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2010 at 12:19pm
The throttle on my AC "M" is on the right side too.
