went pulling friday and saturday
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: went pulling friday and saturday
    Posted: 19 Sep 2010 at 6:39am
Friday night luck as usual .Cut a tire down on the trailor when I pulled into the Fair grounds .Had that to fix no spare .Then came the pulls . Had a decent run going on friday night in 5000 lbs class tractor was pulling second gear well then the govenor weights exploded . revs went high broke traction and spun out . still a decent run good enough for second place. Got home at one saturday morning couldnt sleep wondering what all  damage was done. Got up at seven went back to fair grounds with a extra gov. Installed it thought I had everything back to the same tune as friday night but I was wrong . I was the only guy there Saturday with a tractor that shakes the ground literally and laid down runs like a piece of junk gov. surging spinning the tires every time it surged . Came back home with a broken starter bendix and fridays trophy . Oh well to say I am wondering now of my tuning duplication ability and know how is probably a good conclusion . Seams my bottom quote applies to me.  Sorry to let the allis fans down I promise I will try to get a better hold on what is going on with it.
Edited by mlpankey - 19 Sep 2010 at 6:43am
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 7:26am
Even though you took home the 2nd place trophy, your competitors knew that 1st place would have been riding home with you if not for the govenor weights problem. You know thats whats in the back of their minds. It would be in mine! John Force has bad days too. You didn't let me down. It's a learning experience! Keep the Faith.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 10:22am
At least i wasnt the only one with trubble. The pull i went to yesterday, they tried kicking me out of stock because i had an electric fuel pump, second time this has happened now, apparently they had 30hp or something. Pulled in 5000lbs, spun out with the front end a foot and a half in the air, drive up to the trailer, got off and fluid is pooring from the left side of the tractor, run over a look, lost the adjusting needle from the carb, you would think the needle would be where the puddle of fuel was, nope couldnt find it. so i scratched in 6000lbs. At least i took home 2nd and 30 bucks. Sounds like you had a rough weekend though ml. Better luck next time for the both of us.
Carl
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 11:06am
still looking for the blue line to know the timming is correct but cant find it for the white calcified color. I think the gov. surging is from fuel delivery not being sufficient at full load . but i could be wrong in the info I am interpeting from the plugs.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 5:33pm
    Ya win some and ya loose some.  Some times it is better to be lucky, than good. I'm disappointed too after the  rod ratio, ring placement, etc. discussions. Up here , were done for the year, nothing but "bench racing" or pulling til next spring.  You should have more pulls to go to where you are at  to test your theories . Mebbe you'll get the other , good kind of luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 8:03am
yes garry the rod ratio ring theroy is working pretty well . Its needs 18.4 38 tires and a larger clutch even with a surging gov. dont have enough clutch to hold road gear with the sled attached to it . black smoke rolls from the bell housing.
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 8:13am
Second place Friday is a pretty good feat. You do a lot of work. I am sure you will get a first place finish soon. Good Luck!
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 8:17am
if it dont finish first its junk .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 8:24am
I like the attitude! Second is first loser. You've got it right. First Place is the only answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 8:28am
Originally posted by mlpankey mlpankey wrote:
if it dont finish first its junk . saturday a 560 red diamond international finished first a 77 oliver with a 310 wakesau at 400 cubic  inches and cross flow head came in second a lemmons built h unknown ci  came in third and my piece of junk came in fourth . same way for the three classes before i broke the bendix. top three tractors were on 18.4 38 rubber and i was on 15.5 best finish second friday night .
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 8:53am
Sorry I missed the pull, I had planned on going, but had to much work to do, Hay balers to fix and equip to move. Did they have 4.5 mph speed limit on the super class? The H farmall beat everything last year. Sam T-Ga.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:10am
speed limit was 5.5 mile an hour for the farm and antique tractors with 100 ft to get your speed correct.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 3:58pm
Hopefully you didn't wind up with fragments going any farther than bottom of the pan.
Is a governor 'required' by the rules?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 4:12pm
Stuff Happens but thank God your luck isn't as bad as these guys.
[TUBE]f1OxaVSlY-U&feature=related[/TUBE]
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 7:05pm
Another good reason for me to stick with boats - we can sink the dog if it don't hunt.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 7:33pm
I like a challenge. Too much time and money in it to trash. Just need to back up and see what is going on. Governor weights may be weak link. May need to Tim Taylor it, just like the rest of that motor. Remeber, stronger=faster=better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 7:36pm
After watching that video, I can't help but wonder if the gene pool is going to have a few fewer swimmers...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 7:45pm
"When you stop breaking, you start winning. Ifn you ain't breaking something, you ain't runnin' hard enough."
Deel Me In is National points champ as of today in the APBA 7 litre (468 cube chebby)  class. Only took 10 years to get there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 7:07am
So true we had tires and a clutch that would hold the power we were producing two years ago . Now that we have found some more we need bigger tires and clutch . the gov weights well we have at times had issues with them and worked through them but now they are  back . seams greater power produces greater stress . in more ways than one.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2010 at 7:36am
Carl
shame on somebody for trying to kick a non-stock tractor out of stock ...twice
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
This page was generated in 0.168 seconds.
