Well Well I bought a CAT
Morten.have View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Topic: Well Well I bought a CAT
    Posted: 15 Jan 2019 at 2:10am
Well I indeed need a newer dozer so I bought a cat, before you guys get upset I gonna tell you that I will keep the 16’ for sure!
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 6:14am
Morten:  Nice looking machines - keep up the good work!
Has the swamp pads too -
Orangeman
Edited by orangeman - 15 Jan 2019 at 6:15am
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 8:24am
Nice Tractor Morten. Hope they play nice together. What model cat did you get?
Also meant to ask, how the 16 held up with your ship cargo unload job. Any damage to the beloved HD16?
HD16DC, Bobcat 863 Turbo, Oliver 1855, John Deere 855,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 10:23am
Appears to be a D8C, LGP(Low Ground Pressure) shoes. Going to be loading More ships Morten? By that unit you must have made some good money at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 8:59pm
...at least you can easily source parts....
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 10:30pm
Looking Good. We understand having to update equipment. Good luck with it.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 1:55am
As much as i love my D6Ds; and ive got 2 of them. D6C/D swampys are weak in the final drive dept. Drain and Check the final drive oils. And also check the outer deadshaft nut is tight and the sprocket preloads are tight. The HD16s finals are far more solid than the LGP D6s.  Also crawl underneath and check where the diagonal braces are for the track frames, grease the bearings on each side; and also one each in outer caps.  But mainly check for any oil weeping out of the deadshaft case where the diagonal brace is.  You want it to be nice and dry !
Hope all is good in there.
Cheers Merv
tits tyres and tracks
they all cost you money
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2019 at 1:54am
Are you going to trick out the cab like you did on the HD?
Post a picture of the AC decals I sent you.
Allis Express participant
This page was generated in 0.553 seconds.
