Well, I never……………
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Well, I never……………
    Posted: 09 Jul 2025 at 7:00pm
had this happen before, was grilling today, freshly filled 30# propane bottle, everything going hunky-dory, happen to glance at the temp guage, and temp was slowly dropping, looked over at the bottle and the regulator was frosted over. 89 degrees outside, 54% humidity, gentle breeze from the South.
Bverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2025 at 8:51pm
I fill my own tanks and if I overfill one it will usually freeze up the regulator. A little warm water and it’s going again.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2025 at 9:15pm
Pffft! Child’s play! I once had 3 500 gallon propane tanks hooked together with 2 inch plumbing plus a 4th one with 3/4 inch tied in. They were filled to 250 psi of carbon dioxide, and I emptied them in n less than 2 minutes! Well, not quite, poor little 3/4 tubing couldn’t quite keep up so it was only down to ~50 psi or so. Yes it was on purpose. But you wanna talk about frost! I didn’t need no stinking regulators either!
Yeah. Global warming is probably my fault!😎
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 1:25am
Greta doesn't care any more so it's all OK Wink
In seriousness though, WHY did you have a need to dump that much CO2 at once? That's one huge fire extinguisher!
Stuck Farmer
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 2:12am
Curiosity is getting the best of me, what was you working on with that much co2. Chasing moles or gophers perhaps.
Post Options Post Options   Thanks (2) Thanks(2)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 7:49am
It was a gas/liquid separator test rig. We would inject a known amount of oil into the flowing gas stream and then collect what the device separated and calculate the efficiency of separation. There were many sets of parameters tested, needless to say this was at the extreme top end.
Wanna know the crazy part? This rig was INDOORS and made mostly of ACRYLIC! The boss was big on testing stuff with acrylic so you could see what was going on. Yes of course the discharge was routed out the window. But if there had been a failure on that run I could have been possibly suffocated.
And yes, the sound of this particular test run was absolutely deafening!
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 3:57pm
Thank you for the explanation; I am often amazed at some stuff folks do for a living. Smile
This page was generated in 0.189 seconds.
