well I did it now
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Topic: well I did it now
    Posted: 05 Nov 2011 at 6:22pm
I thought I would remove the oil lines to the turbo on my 190XT to make installing the injector lines easier and wouldn't you know it lay a wrench on the pressure line and the fitting breaks off in the turbo bearing housing (in my defence it was cracked half way already.) Brass out of aluminum my the combintion I love the most. Well I ended up cracking the bearing housing trying get it out, so now I guess it is time to find another Turbo. Has anyone tried a used turbo?
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 6:58pm
That sucks !! Depends on the price , if a used one is cheap enough , I,d give it a whirl ;  is that 190 xt with the duals still sitting in Syracuse ?
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 6:59pm
Stray I can't wait to hear answers. I may need to replace mine this winter if it needs it. Good luck.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 8:47pm
Work tractor you depend on: New/Rebuilt turbo, Show tractor/play toy: used turbo if the price is right.  When I needed a new turbo for my 7000, it wasn't much difference in price between new and used (used was going to run around $300 shipped if I remember correctly, and new was around $550), and I could drive and pick up the new one that day about 40 minutes from my house.  Plus, you have a warranty, all the gaskets you need, and peace of mind.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 9:05pm
No, I had been watching this one sitting in a fence row near where I bale hay. It was just sitting for about 4 years. I think all it had done the last few years it was used was to pull a 10 ft brush hog for 1 day a year. I looked around the one that Rick has there at Syracuse Implement, it seems to be in pretty good shape.
1969 190XT series 3
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 9:50pm
What brand is your turbo? That could make a difference on price. A air reserch won't replace a TRW woth out changing cross over and other pluming.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 9:52pm
Mine is a TRW
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 5:19pm
Has anyone rebuilt their own turbo? I found a good core turbo and I am going to try to rebuild mine using the bearing housing from the core turbo. Does anyone know where I can get seal kit for a TRW turbo? Does Agco still sell them? Does anyone have any tips this will be the frist complete turbo rebuild that I've done, but I'm a very experance mechanic and there hasn't been able to rebuild once I started.
1969 190XT series 3
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 9:53pm
If I remember right the nut on compresser is left hand thread. Be carefull the shaft is small and will bend easy. Been a while since I worked on one. MACK
