Welding projects
IBWD MIke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: Welding projects
    Posted: 07 Nov 2021 at 7:19am
Had to fire up the welder awhile back, broke a coulter mount plowing. As luck would have it, none of my other plows have that style mount. My concern with welding it was the fatigued area next to the break. I ground it back a long ways in the classic 'V', It welded very nicely.
The other project is a bit more of an experiment! Last fall after putting the 16.9X28's on the narrow front, the sub-soiler wouldn't go in the ground to full depth. My idea was to offset the latch eye. Picked up an eye at Hutch, used an old piece of plow frame for the other half. 'V'd them both, preheated and together they went. I'm not sure what the steel in plow frames is but it's pretty hard, the preheating helps with under-bead-cracking. At least I hope it does. Should have time to get this on the soiler today, will give it a try if I do. Ground is really too wet so won't do too much, just see if it works.
Edit; As usual pictures are out of order but you get the idea.
Edited by IBWD MIke - 07 Nov 2021 at 7:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 7:51am
I was in our weld shop one day this week and saw a new sheet of mild steel 4 ft x 8 ft  that was 1/4" thick. I said to my welder, that cannot be the correct price written on it, is it ?? He said yes.....$600 bucks  !!!!   He said it is more than double what it was a little over a year ago. That is not inflation, that is hyper-hyper inflation and I'm afraid of how long this is going to last. Save your old steel !!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 8:30am
very nice weld bead............. preheat sure does wonders on the hard steels.... grind the rust off to CLEAN metal as you did helps a lot... i even wire brush a 1/2 inch PAST where the weld will be so it does not suck any rust into the final weld...again, NICE BEAD.... is that 7018 ?
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 2:03pm
Look good Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 4:19pm
Why not just make 2 plates so that everything bolted together? Ermm Then If you need to make a change to get it deeper you could angle the spread on the holes a bit.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 7:18pm
But then you don't get to play with the welder!
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 8:02pm
Doc, I hear you! I don't scrap anything unless it really is scrap!
Steve, it is a mild steel tig rod.
Kenny, thanks.
Paul, I really don't follow?
Farmboy, exactly!
I got this thing installed on the soiler today, had to do a little 'fitting', aka grinding, to get it together. Hooked it on the narrow front for a test spin. I love this thing but it is the most cantankerous snap-couple implement ever! Just a pain to get hooked up to.
I took some pictures to post but apparently left the camera at the farm. Will try to get them posted tomorrow.
As I suspected, It's really to wet to use this thing, ran it some but not working like it should. High point is, now it goes in the ground like it should. Hard as it pulled today, pretty sure if the weld was going to break it would have happened already.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 11:48pm
Looks good Mike.
WHY is it so hard to hook up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2021 at 7:27am
Ted, on other snap-coupler implements the drawbar is right there at the right height. Back into it, snap, hook up the links, and away you go. With the soiler, the eye is on the ground and it's laying on one side. Think I'm going to make some kind of a stand or pair of. It could be supported by rafters with wire possibly. Then if I can just find the right spot in a shed...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2021 at 8:30am
Mike, i have a couple small "stands" that i use to support the 4x4 truck and equip when jacking them up..... i cut a dozen 2 x 4 about 8 inches long.. stack them like lincoln logs and spike each layer with  16 penny nails to the layer below.. You end up with a BLOCK that is 8 x 8 inches and as tall as you want...... i have a couple that are 14 x 14 base for BIG stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2021 at 10:14am
Take two plates, drill 4 hole that match the eve and implement in a square pattern and then bolt together with the eye above the implement hitch. This would allow everything to be put back original when said implement is use on a tractor with "normal" rear tires.
  In my lifetime I've probably welded more miles of bead that many young ones have driven, so I look for other ways to make things that don't destroy original parts.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2021 at 10:22am
TIG eh?  Those were fantastic looking beads, would have been an accomplishment to be proud of for sure coming off an arc welder.  Not saying it couldn't have been, just saying a TIG sure makes a clean weld, and of course you still have to know what you're doing.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2021 at 11:11am
It should have had a parking stand
There usually lost once the original owner sell it. There should be a picture of it in the operator's manual.i dont have a subsoiler but when I was a kid and we went to get parts at the dealer every piece of equipment that didn't stand on it own had a parking stand. Luckily my loader and mower both came with stands makes hooking Nd unhooking extremely easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2021 at 1:30pm
Paul, I saved the original eye, this one is probably from a plow?
Steve, thanks for the idea on the stands. I remembered some that I have, came home from work, think I can make them work without much work.
Dave, I'll look in the manual, don't remember seeing one in there in the past but...
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2021 at 1:42pm
Found the camera in the toolbox on the tractor.
Some shots of the mod and sitting on stuff to get hooked up.
It goes in the ground now!
I had taken the weights off for a tractor pull last summer, put one pair back on, not enough. Added about 1000 Lbs. of ballast, much less tire slippage now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2021 at 3:42pm
LOOKS GOOD !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2021 at 8:28am
Thanks Steve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2021 at 3:49pm
Mike,
 Your tearing the place up! Looks like the subsoiler is working well. Good welds!
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2021 at 7:38pm
I used to struggle when hooking up my #4 subsoiler too, until I read the owners manual. Prop it up vertically with the pull bar on the ground. Back over the subsoiler pull bar until the lift arms are under the couplers. Attach the lift arms and lift the unit off the ground. Grab the subsoiler shank from behind, pull back and align the pull bar eye with the snap coupler bell. Swing the unit forward until the eye snaps in the coupler.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 7:59am
I'm surprised adjusting the top link would have allowed you to get the subsoiler to go full depth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 8:45am
Chris, thanks.
Dave, correct you are! Right there on page 5, someone probably should have read that darn thing.
As to the future, I will be building stands so that you can hook/unhook like any other S/C implement, stay tuned.
Supposed to rain quite a bit around here today, probably done using this thing for the year. Try again next fall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2021 at 8:46am
Well, here is the stands. They came from work, come in on new hoists we put up. Just welded the hold-down straps together. Had to torch the new holes in the angle iron, couldn't get them in my little POS drill press. Mounted and in the shed.
Now if I can get the pics in the right order.
Edited by IBWD MIke - 25 Nov 2021 at 8:51am
