Welding on chrome?
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Topic: Welding on chrome?
    Posted: 06 Dec 2022 at 9:46am
The chrome running board on my truck rusted around the 'tabs' and the running board fell off. Looks like I could make some new tabs and weld them to the bottom of the running board and be good as new, lol.
I do not remember ever welding something that is chromed, is it something that has to be prepped or will a 6013 stick to it right out of the tube? Other considerations?
Thanks for your thoughts.
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2022 at 9:56am
Grind the chrome off first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2022 at 9:57am
Chrome is a surface finish usually over brass or copper coating to adhere better, will not weld, need to do any welding around chrome with a Outside Source Air hood. Will have to remove chrome finish to base metal to weld.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2022 at 10:06am
Wow, more to it than I thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2022 at 10:24am
old skool  'triple plated chrome' was
base steel <-copper <-nickel <-chrome
basic process was clean steel, electroplate copper to it, electoplate nickel to the copper, then electroplate chrome to the nickel. each step has a LOT of labour*sanding,buffing, etc. and of course a LOT of NONuser friendly chemicals..acids and such...
have no idea what  is used today....
but, yess, need to  grind off 'chrome' to bare steel, weld, clean up THEN decide IF you want/need 'chrome' on the repair.
2 options..
1) old skool, require piece to go to plating shop, $$$$$$ and more $$$$$
2) prime and spray paint 'chrome - like' paint
3) brother got some 'markers' from hobby shop and they look very nice like chrome
Edited by jaybmiller - 06 Dec 2022 at 10:27am
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2022 at 10:25am
Don't breath the welding fumes even after grinding it off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2022 at 12:40pm
scott... its not that difficult.. Your on the BOTTOM of the board. TAke a die grinder the grind off the chrome till you see CLEAN STEEL.. Go out about  1/2 inch past where you will weld. Do your welding as needed.. You might actually damage the chrome on the OPPOSITE side, depending on how hot and how thick the metal is... After welding, just touch up the bare metal and new bracket with aluminum or galvanized paint...
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2022 at 1:29pm
If you have any doubts or concerns make a bracket you can bolt to. Then get some chrome or stainless bolts and bolt it on.
