Welding cheater
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Welding cheater
    Posted: 07 Sep 2025 at 5:16am
What do you with aging eyes do for a cheater in an auto darkening helmet?
I use my glasses but still can’t see as well as I like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 5:36am
Have tried the Cheater inside lens sets, did not like as not close enough, still using my 1.5 cheaters under the hood, did lighten the auto dark feature a step at a time until could see without injury.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 7:53am
yes... if youi lightne up the setting on the "DARK" it helps a bunch.. Dont go below the "8" mark if you do much welding... Flash will eventually get to your eyes and make them sore... Many people use the 11-12 settings... Try the 9 and see if that helps. ....... and i keep my glasses on (bifocals) for the close up work.
Edited by steve(ill) - 07 Sep 2025 at 7:54am
Jgranat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgranat Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 9:06am
I find I weld better without my bifocals because I never can get the correct angle to make my vision clear while wearing them.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 9:12am
I never liked the "cheaters" as the best focus area was never right for me.  I use a pair of drugstore reading glasses of the right magnification for my eyes under the helmet.  Much more satisfactory for me.  If I'm doing TIG welding I use reading glasses with one more power of magnification.  Works for me.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 4:17pm
Lots of older men tend to go farsighted with age, they can get along without glasses for most things such as driving, etc. but are unable to focus up close, hence the need for 'cheeters'.
I have the opposite problem of being quite nearsighted, plus heavy astigmatism. I can see well enough without glasses to walk around the house, but that's pretty much the limit. I wear tri-focals all the time, but there is no way I can tip my head around to see through a welding hood.
My solution is to remove my glasses while welding; the process goes like this: remove glasses, put hood on, put gloves on, weld, take gloves off, take hood off, put glasses on, see that I missed the spot entirely, grind off the improper bead, repeat, etc. etc.
I never really wanted to be a welder anyway!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:58am
I think I’ll try some of those readers. I wear trifocals and can’t ever get everything just right.
I do set it at 9 and go when mig welding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgranat Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:52am
This is also my method.....
"take hood off, put glasses on, see that I missed the spot entirely, grind off the improper bead, repeat, etc. etc."
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:12pm
My eye glasses have had the auto darkening photo grey lenses for 50 years. Welding infrequently it took me 20 years to figure out that I did not need as dark a lenes as normal. But it would be less than 30 years of having a auto darkening helmet, with a adjustable darkness settings for arc welding.
Being near sited I could weld without glasses, but in general I never think to take them off. Also so I am not like my wife with a dozen pair, but never having them when she needs them. And they have worked as safety glasses more than once as well to keep falling dirt out.
Because of lens fogging started using a face shield for oxy acetylene work. Did not know they had more than one darkness of the plastic face shields. But came home with 3 instead of a 5 one time. With the photo grey in the glasses was plenty dark.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 28 minutes ago at 9:31am
reading glasses here and go for it!! hands shaky are a bigger problem!
