Weird cam??
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Topic: Weird cam??
    Posted: 28 Jan 2025 at 11:11am
   Now that Ed is lurking about...  the reground cam in my pulling tractor is second hand, did not get a card, guys did not recall who ground it, some one in Indiana???
   It was for a 3000 RPM class, thats why I added larger ratio rockers.   Here is strange I think, rough measurements for valve opening after rockers is  Intake .500 , ex .610.
   Does this seem odd ex is so much higher lift??? I know they want the hot gass out to spin turbo but it is already getting shoved out by piston.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 11:21am
Would it be a Vogel cam grind ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 11:25am
  Possibly, bought from some youth, did not seem to care who reground it.  Would make sense.    They claimed it was somebody with a rep.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 1:34pm
It's pretty common for the exh side to have more lift AND duration. With this goofy flowing AC head though, I've talked with several guys a lot smarter than me about having one ground to favor the intake side, since head flows really good on exh side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 2:18pm
    Thanks Ed,   since I filled my head with grout I actually got the intake to flow much more then ex.
    Still might replace cam down the road, they are always learning.
Edited by NEVER green - 29 Jan 2025 at 8:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2025 at 8:22am
My head has been worked over by Bob Himes, and it flows pretty good for what it is, but intake still not as good as my competitors likely are lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2025 at 9:21am
   Wipe Out sells ported IH  heads , stock one with stock valves flow 285CFM ,  stock one with big valves flow  360CFM.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2025 at 10:56am
One of my pet peeves is Allis NEVER changed the profile of their cams - they did change a 'quietening curve'  on later engines but the specs as to lift , duration and degrees did not.
Surely from naturally aspirated engines of the 60's to the turbo'd 4.33 - 7020 or 8070 they could have made a difference in efficiency and performance.  How many cams are available for a 350 Chevy, Chrysler  or Ford ?   Rumor was that when they changed the cam on the D262 on the D19 - kept the intake open longer - it would not start so they had to change them out (first ones) . The lesson was to engineering - leave it alone. Bad lesson.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 8:28am
   I had one of my cams reground by Colt Cams and he did not like the stock profile, forget the exact complaints, been awhile and they were numerous.
   I was told the quieting part of the engine was done with the Bosch injectors on the 8000 series. Rumor?? That and they lowered compression where  in my book you should get a different cam.
   You are right, Ford offered several cams right from the factory for their engines, RV, police, truck, high performance.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2025 at 9:33pm
Last time MY head got filled with grout, the result was terrible... my ex flowed with continuous displeasing commentary, NOW she understands why I REFUSE to DO TILE.
Ouch LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 8:13am
Ouch LOL
   God gave us all a sense of humor for good reason.Wink
