Weeds, grass and grain ??? |
| Author | |||
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
Topic: Weeds, grass and grain ???Posted: 06 Jul 2023 at 1:13pm |
WHat do I have here ?
#1 ![]() #2 ![]() #3 ![]()
| Sponsored Links | |||
Joined: 11 Sep 2009 Location: illinois Points: 88671 |
Posted: 06 Jul 2023 at 1:45pm |
could be a form of wild grass...
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2682 |
Posted: 06 Jul 2023 at 2:17pm |
Do you happen to have a county agent or a farm agent that could come out and answer your questions and give you some help and guidance? Pics are nice but in person might be an idea. Good luck on with your plan.
John Phillis
Joined: 05 Jul 2023 Location: Burgettstown PA Points: 39 |
Posted: 06 Jul 2023 at 10:07pm |
Looks like a field that could be close to where I live.
June grass(I see some dogbane in there too) Fescue Fescue, Oxeye Daisy, Timothy Very typical for Washington, Beaver, Greene, Allegheny… Is that in western PA?
Macon Rounds
Posted: 06 Jul 2023 at 10:16pm |
Yep
Hookstown area... The first 2 photos I believe are some kinda fescue but not for certain. Goes to seed about the same time as orchard grass. #3 photo came in combination with some deer food plot mix... The purple looking stuff. Can not identify. Yet ... Edited by Macon Rounds - 06 Jul 2023 at 10:20pm |
John Phillis
Posted: 06 Jul 2023 at 11:43pm |
Hookstown is about 15-18 minutes away from me.
The purple headed stuff is fescue. It’s most likely Kentucky 31 fescue. It grows good around here and it is most common in seed mixes. Handles the dry weather nicely. Have you seen the prices on small squares of alfalfa at the Rogers hay and grain auction? It peaked a few weeks back at $14.00 a bale! I have had good luck with the FS forage round up ready alfalfa seed, and a hay grass mix from Growmark in 84 called “hay buster”. Nothing beats the good old Timothy/alfalfa mix around here. Seed it down in the fall with a wheat nurse crop, or in the spring with an oats nurse crop. If you do go with the oats nurse crop, I would buy all of the oats you take off the fields. How are your fields on lime?
Macon Rounds
Posted: 07 Jul 2023 at 9:02am |
I have 2 different fields about 10 acres that i have brought up to low 6's...
All the other fields are in low 5's..... Grubs brother profesionaly put correct type lime on for us, "2 years ago".... Lime is at $37 a ton here... And it is hard to get... Very disappointed in the fields I limed. County agent said bringing lime levels up would help soil to naturally release other P/K/N firtility .... Which makes sense but no visual difference is evident.... We have also top dressed those 2 field with firtilizer after 1st cutting last year... Made a difference last year but those fields are back to similar to untreated fields this year. |
Macon Rounds
Posted: 07 Jul 2023 at 9:07am |
I assume you need to
"no till" the wheet or oats into the existing hay field ? The county does have one to rent. Others have suggested broadcasting seeds of ????? ... |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Posted: 07 Jul 2023 at 12:12pm |
It’s positively not a fescue we plant fescue for hay on sandy ground. There is an app ( not free) where you take a pic of a plant and it identifies what you got. YOU DO NOT WANT TO PLANT WHEAT OR OATS DIRECTLY AFTER A HAY CROP. Google “take all” its a disease that will pretty much kill/stunt all the wheat. Run a year of corn clean or beans in between. No till wheat works decent after beans then you can no till alfalfa into the wheat stubble. Another option would be to get a Agtalk logon and post your grass pics their very smart group of guys most active farmers.
Ben (MI)
Joined: 02 Jun 2010 Location: SW Lower MI Points: 769 |
Posted: 07 Jul 2023 at 12:20pm |
I think Vic is referring to Google lens, I use it occasionally and it is very helpful. Best to have each plant photo by itself. If you have a good agronomy company nearby take a couple of each plant in and an agronomist could help.
Part time farming with a 1980 7060 and 1984 F3 hydro.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12255 |
Posted: 07 Jul 2023 at 1:22pm |
Interesting. Had a MSU agronomist and a big farmer in separate conversations tell me following hay with wheat could work. Just had to do a thorough kill on the hay. |
victoryallis
Posted: 07 Jul 2023 at 7:08pm |
Personal experience and plenty of research following tells me it doesn’t. Read the first paragraph from Kentucky http://plantpathology.ca.uky.edu/files/ppfs-ag-sg-01.pdf Edited by victoryallis - 07 Jul 2023 at 7:15pm |
John Phillis
Posted: 07 Jul 2023 at 8:58pm |
Hi,
I don’t think he has to worry much about take all. He is perched on the top of a hill, has plenty of slope, temperatures stay a lot warmer in the early fall/late summer, and he has low ph soils. This is not a common problem for this area. Are you saying that the purple hued grass heads are not fescue? Maybe I misunderstood.
John Phillis
Posted: 07 Jul 2023 at 9:14pm |
Lime is pretty easy to get here. It’s available for free in Dunningsville. You just have to have a triaxle or hire a trucking company. You can call Yost Trucking in Canonsburg and have them haul it from the Dunningsville exit of I-70. They do it all the time. After seeing some other pictures of your farm in another post, I am fairly certain that I know where your farm is. Your neighbor Tim Kelly rents the lime spreaders to spread the lime. So for a fairly small amount of money you can get a good dose of lime out there. And if you’re where I think you are (farm was owned by a family who went to mill creek and his wife was the organist) then you are literally a few hundred feet away from rental lime spreaders. Much better to have the ground tilled and work the lime in. Hope this helps John
John Phillis
Posted: 07 Jul 2023 at 9:29pm |
So, I wouldn’t exactly do that. I mean, if you want to pick a few strips, or a single strip of maybe 5 acres and burn it down in late July, then wait until everything is brown and down for at least two weeks (no green bridge). Then hit it with a couple tons of lime, and finally sow it in tillage radishes with 100 lbs of potash in august to set it up for a spring seeding of hay with an oat nurse crop; that will work. The ground will be fairly mellow and clean to sow. I think it would be better to just pick a strip or a few strips and moldboard plow, disc, and then lime, then disc in the lime for fall planting of wheat nurse crop over hay. Or, if you want to fall plow it and then lime and disc(or harrow, digger, field cultivator) in the spring for a spring planting of the oats and hay that would work also. If you are retired and just want to play and get paid for the hobby, then try all three methods! I’d be curious to see how it all goes in a side by side comparison. It would be interesting to see how it all turns out. Some people retire and play golf. Then there are those who retire and farm and end up working harder at farming and are happier and healthier and get paid money back instead of paying for the golf! ![]() Let me know if you have any questions John
Macon Rounds
Posted: 07 Jul 2023 at 9:56pm |
Hey John
I'll send you a PM with my phone number. Sounds like we know each other or we should. So many different approaches to farming. I am not wanting to brake the bank on buying equipment or put myself into payments for for seed and firtilizer... I don't wanna spend my retirement years paying for farming.... Ha ha !!! I believe with experts like you and your experiance I can farm and have fun doing it.... I know the Kelly's well and have spoken to them numerous times.... I guess I need to investigate other lime sources but I have heard many people and truckers say the lime coming in by trains and barges are a fraction of what they were a year ago. Hence $37 a ton... That is dilivered by triaxle... And I really didn't wanna make myself another job of spreading lime... That is why I chose grubs bro. TTYS |
John Phillis
Posted: 07 Jul 2023 at 11:23pm |
I understand that! It’s not fun if it becomes too expensive or too much work!
The last lime I got, having had it trucked to the farm, came out to $7.83 per ton, and I can’t remember what I paid to Kelly’s for renting the spreader but it was reasonable. I have to get more delivered this year for a couple fields so I’ll be able to let you know what the updated price will be. Probably still close to $8 per ton. I usually just do a few fields every year and then it’s not too much work all at once. Fertilizer is a bit expensive now, but it looks like you are off to a good start with getting the farm built back up. Have you done any spraying for the weeds? It’s a nice farm in a nice area, definitely a beautiful retirement plan! John
Macon Rounds
Posted: 07 Jul 2023 at 11:41pm |
$4 / acre for Kelly's spreader.
PLEASE let me know were you get lime for $8 a ton... Sent you PM with my cell # Still working in shop if you wish to call . |
Tbone95
Posted: 08 Jul 2023 at 7:45am |
All I said was; Interesting. |
