WD45D water pump
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Topic: WD45D water pump
    Posted: 17 Oct 2018 at 5:41pm
Bought an aftermarket water pump for our wd45 diesel and there is no dowl pin on it. Im going to drill a hole for one and install a pin. Has anyone else came across this issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 9:21pm
What dowl pin? The only pin there is in the gasket and that goes in the small hole in the head.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2018 at 5:56am
Thats what im talking about Matt. There is no pin thru the back plate to keep the pump passages in alignment to the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2018 at 10:34am
The little pin that's in the gasket keeps the gasket lined up with the head. The water pump is kept in alignment with a short peice of flat steel that bolts to the back of the water pump and to the front of the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2018 at 4:39pm
Thanks for your help. I found the bracket!
