WD-45D air cells |
Author | ||
Tom IA ![]() Silver Level ![]() ![]() Joined: 17 Sep 2009 Location: Donahue IA Points: 255 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Feb 2019 at 9:42am |
I am working on a wd-45D tearing down the head want to remove the air cells book said special puller do not see where a puller could attach only small hole in top to turn ,also looking for one rod and front pulley may need other parts also THANKS Tom
Sponsored Links | ||
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
If you are very very careful and use a very soft brass or copper punch, you can punch them out through the injector hole. But the best way is to remove the cap and get the correct puller , if I remember correctly the cup is threaded 1"- 14 tpi
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24651 |
OK I gotta ask what the heck are 'air cells' ??
Dnoym N. S. Can. ![]() Orange Level Access ![]() ![]() Joined: 03 Oct 2009 Points: 544 |
will this work Buda Diesels used the Lanova System, here are some of the air-cells after bead blasting and lapping the caps to the cells
The Lanova System uses these air or energy cells to pull a small amount of compressed air into them. As the injector fires, a small amount of fuel is directed into the cell and fires in this chamber just as it fires in the combustion chamber. With the orifice in the cell, the ejected energy is metered out and continues to push on the piston as it travels down. The out flow also swirls the air/fuel mix giving a cleaner more complete burn in the cylinder. This system is very efficient and provides lots of medium rpm torque.
I used the bolt from the puller to hold the cells while lapping them to the head using medium valve grinding compound
HTH B:-) Dnoym
wide ![]() Silver Level ![]() Joined: 29 Dec 2018 Location: north iowa Points: 169 |
Like an indirect injection, "IDI", prechamber on an early VW diesels,..
instead of direct injection into the piston. |
Some are threaded and some are not. MACK
thank you..nice to learn something new everyday!
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Like Mac said the replacement units are not threaded that makes them harder to remove.
THANKS guys the information and pictures help a lot manuals don't show much, does anyone have any wd-45D rods? THANKS Tom
Yes, I have some used rods, but won't have the rod drilled or wrist pin oiling. MACK.
Just out of curiosity, what do you do if the orifice in the cell is eroded badly?
Well Brian the good news is AGCO has them new but the bad news is they are not cheap.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8612 |
They way I see it,be very happy you can buy new! Forget the price.
WD45Diesel57 ![]() Orange Level ![]() ![]() Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
i have a few rods out of a 262 diesel if there the same? id ship one to you!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Still having trouble getting the cap out haven't got to air cell yet been soaking made a tool to go around it with a pin in to try to turn it what about heat? did not want to heat being those heads are so fragile any ideas
Tony.Or ![]() Orange Level ![]() ![]() Joined: 18 Mar 2010 Location: Oregon Points: 1498 |
Tom !! I have some used wd45d rods. Tony 877-602-3994
