WD45
don View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote don Quote  Post ReplyReply Direct Link To This Post Topic: WD45
    Posted: 27 Mar 2011 at 8:36am
can a D17 engine be put in a WD45
bubschooley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bubschooley Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 8:47am
yes they can be put in a wd
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 5:34am
Use the 45 water pump and crank pulley.17's stick out too far for use in a 45
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 11:54am
the crank snout on the D17 eng is longer than on a 45 eng,  the 45 crank pulley will go on but will set toward the radiator by about and 1/2 inch, so youll have to fab a spacer for your water pump pully to space it out and redrill the hole for the gernerator mouting to line everything up to the crank pulley.   The oil lines on the right side of the eng alos interfear with the steering shaft and can be rotated just a little to miss the shaft.  HTH
This page was generated in 0.184 seconds.
