WD45 |
acd17toy
Topic: WD45Posted: 01 Sep 2025 at 6:43pm |
When pulling the gear shift tower should the transmission be in a sertin position?
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1589 |
Posted: 01 Sep 2025 at 7:49pm |
I would try to have in neutral if possible. But I do not know if that is correct! Never had mine apart.
Dennis(IA)
Posted: 01 Sep 2025 at 8:06pm |
I had mine off a lone time ago (20 years). I took it off in neutral, but then I had a difficult time to put it back on. It seems to me that it had to be in reverse to replace it. Everyone I talk to says it should be in neutral. I don’t know what my problem was.
Dennis(IA)
Posted: 01 Sep 2025 at 8:13pm |
Are you pulling the shifting lever or the whole transmission cover? My comment refers to the whole cover.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4270 |
Posted: 02 Sep 2025 at 6:53am |
I believe 2nd gear is where you want it, been a few years since I had one apart. Mine was jammed in two gears so it came apart where it was. Took several tries before I got the tranny in 2nd and back together.
There are some pretty good shift-tower threads on here if you search. Sugarmaker did one.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 02 Sep 2025 at 8:33am |
What does the service manual say???
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8971 |
Posted: 02 Sep 2025 at 9:50am |
Mike is correct 2nd gear. Shift collar and tower in position.
acd17toy
Posted: 02 Sep 2025 at 6:56pm |
dr p
Joined: 24 Feb 2019 Location: new york Points: 1526 |
Posted: 02 Sep 2025 at 7:20pm |
Sandy lake implement has a complete description on how to do it on their knowledge section
